HetuEngine Intelligent Materialized Views
Overview
HetuEngine intelligent materialized views provide intelligent precalculation and cache acceleration. The HetuEngine QAS role can automatically extract historical SQL statements for analysis and learning, and automatically generate candidate SQL statements for high-value materialized views based on the revenue maximization principle. In practice, HetuEngine administrators can enable automatic creation and refresh of materialized views by configuring maintenance instances. Service users can configure client sessions to implement automatic rewriting and acceleration based on automatically created materialized views.
This capability significantly simplifies the use of materialized views and accelerates analysis without interrupting services. HetuEngine administrators can intelligently accelerate high-frequency SQL services by using a small amount of compute and storage resources. In addition, this capability reduces the overall load (such as CPU, memory, and I/O) of the data platform and improves system stability.
The intelligent materialized view provides the following functions:
  • Automatic recommendation of materialized views
  • Automatic creation of materialized views
  • Automatic refresh of materialized views
  • Automatic deletion of materialized views
The cluster is running properly and at least one QAS instance has been installed.
Application Process
Figure 1 Application process of HetuEngine intelligent materialized views
Table 1 Process description
Step
Reference
Enable the materialized view recommendation function.
After this function is enabled, QAS instances automatically recommend SQL statements of high-value materialized views based on users' SQL execution records. You can view the recommended materialized view statements on the materialized view recommendation page on the HSConsole. For details, see Viewing Materialized View Recommendation Results.
Enabling Materialized View Recommendation
Configure a maintenance instance.
After a compute instance is set as a maintenance instance, the maintenance instance automatically creates, refreshes, and deletes the materialized view SQL statements recommended by the materialized view recommendation function. You can view the generated automatic task records on the HetuEngine automation task page. For details, see Automatic Tasks of HetuEngine Materialized Views.
Configuring a HetuEngine Maintenance Instance
Enable rewriting of materialized views.
After rewriting is enabled for materialized views, HetuEngine determines whether the materialized view rewriting requirements are met based on the SQL statements entered by users and converts queries or subqueries that match materialized views into materialized views, avoiding repeated data calculation.
Rewriting of HetuEngine Materialized Views
