On this page
Overview
This section applies only to MRS 3.2.0 or later.
ClickHouse Multi-Tenancy
The ClickHouse multi-tenancy feature enables you to manage cluster resources through the user > tenant role > resource profile management model. Currently, memory and CPU priority management is supported. The following figure shows a multi-tenancy model.
On the service configuration and tenant management pages of FusionInsight Manager, you can configure memory quotas for services, create tenants, associate ClickHouse services, bind logical clusters, set available memory and CPU priorities for tenants, and associate tenants with users. The following figure illustrates the role association between Manager and ClickHouse.
The following table lists the resource configurations supported by the current version.
Resource
Value Range
Remarks
Service-level memory resource limit
0–1
Percentage of available ClickHouse memory to total server memory
For example, if the physical memory of the server is 10 GB and the limit is set to 0.9, the available memory of the ClickHouse service on the current server is 9 GB (10 GB x 0.9).
Tenant-level memory resource limit
0%–100%
Percentage of the available memory of the current tenant in ClickHouseServer
If this limit is set to 80, the total memory that can be used by the current tenant is calculated as follows: Total memory that can be used by the service x 80%
Tenant-level CPU priority
–20 to 19
NICE value of the OS associated with this value. A smaller value indicates a higher CPU priority of the process.
This feature depends on CAP_SYS_NICE of the OS. By default, this feature is disabled after the cluster is installed. To use this feature, enable it by referring to Configuring CPU Priority for ClickHouse Tenants.
