HetuEngine Materialized View Recommendation
HetuEngine QAS module provides automatic detection, learning, and diagnosis of historical SQL execution records. After the materialized view recommendation function is enabled, the system can automatically learn and recommend the most valuable materialized view SQL statements, enabling HetuEngine to have the automatic precomputation acceleration capability. In related scenarios, the online query efficiency is improved by multiple times, and the system load pressure is effectively reduced.
- The cluster is running properly and at least one QAS instance has been installed.
 - You have created a user for accessing the HetuEngine web UI, for example, Hetu_user. For details, see Creating a HetuEngine Permission Role.
Enabling Materialized View Recommendation
- Log in to FusionInsight Manager as user Hetu_user.
 - Choose Cluster > Services > HetuEngine and then choose Configurations > All Configurations. In the navigation tree, choose QAS(Role) > Materialized View Recommendation. Set materialized view recommendation parameters by referring to Table 1 and retain the default values for other parameters.
Table 1 Materialized view recommendation parameters Parameter
Example Value
qas.enable.auto.recommendation
true
Whether to enable materialized view recommendation. The default value is false.
qas.sql.submitter
default,zuhu1
Name of the tenant for which the materialized view recommendation function is enabled. Use commas (,) to separate multiple tenants.
qas.schedule.fixed.delay
1d
Interval for recommending materialized views. Once a day is recommended.
qas.threshold.for.mv.recommend
0.05
Filtering threshold of materialized view recommendation. The value ranges from 0.001 to 1. You are advised to adjust the value based on the site requirements.
 - Click Save.
 - Click Instance, select all QAS instances, click More, and select Restart Instance. In the displayed dialog box, enter the password to restart all QAS instances for the parameters to take effect.
Viewing Materialized View Recommendation Results
 - Choose Cluster > Services > HetuEngine to go its service page.
 - In the Basic Information area on the Dashboard page, click the link next to HSConsole WebUI. The HSConsole page is displayed.
 - Choose SQL O&M > Automatic MV Recommendation. You can search for materialized views by tenant, status, recommendation period, and materialized view name. Fuzzy search is supported. You can export the recommendation result of a specified materialized view.
    The status of a materialized view task can be:
Table 2 Status of a materialized view task Status Name
Status Name
To Be Created
To be created
Deleting
Terminating
Creating
Creating
Deleted
Terminated
Created
Created
Planning
Being planned
Failed
Creation failed
Aborted
Aborted
Updating
Updating
Duplicated
Repeated recommendation
