Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using CDL/ Creating a CDL Job/ Synchronizing Data from Hudi to ClickHouse Using CDL
Updated on 2025-08-22 GMT+08:00
This section describes how to import data from Hudi to ClickHouse by using the CDLService web UI of a cluster with Kerberos authentication enabled in MRS 3.2.0.
  • The CDL, Hudi, and ClickHouse services have been installed in a cluster and are running properly.
  • You have operation permissions on ClickHouse. For details, see Creating a User with ClickHouse Permissions.
  • You have created a human-machine user with the ClickHouse administrator permissions (for details, see Creating a User with ClickHouse Permissions), for example, cdluser, added the user to user groups cdladmin (primary group), hadoop, kafka, and supergroup, and associated the user with the System_administrator role on FusionInsight Manager.
  • You have manually created a local table and distributed table on ClickHouse. The local table uses the ReplicatedReplacingMergeTree engine. For details, see ClickHouse Client Practices.
  1. Log in to FusionInsight Manager as user cdluser (change the password upon your first login), choose Cluster > Services > CDL, and click the link next to CDLService UI to go to the CDLService web UI.
  2. Choose Link Management and click Add Link. In the displayed dialog box, set parameters for adding the clickhouse and hudi links by referring to the following tables. Creating a CDL Database Connection describes the data link parameters.
    Table 1 ClickHouse data link parameters
    Example
    Link Type
    clickhouse
    Name
    cklink
    Host
    10.10.10.10:21428
    User
    cdluser
    Password
    Password of the cdluser user
    Table 2 Hudi data link parameters
    Example
    Link Type
    hudi
    Name
    hudilink
    Storage Type
    hdfs
    Auth KeytabFile
    /opt/Bigdata/third_lib/CDL/user_libs/cdluser.keytab
    Principal
    cdluser
  3. After the parameters are configured, click Test to check whether the data link is normal.
    After the test is successful, click OK.
  4. (Optional) Choose ENV Management and click Add Env. In the displayed dialog box, configure the parameters based on the following table.
    Table 3 Parameters for adding an ENV
    Example Value
    Name
    test-env
    Driver Memory
    1 GB
    Type
    spark
    Executor Memory
    1 GB
    Executor Cores
    Number Executors
    Queue
    Click OK.
  5. Choose Job Management > Data synchronization task and click Add Job. In the displayed dialog box, set parameters and click Next.
    Parameters are as follows.
    Example
    Name
    job_huditock
    Desc
  6. Configure Hudi job parameters.
    1. On the Job Management page, drag the hudi icon in the Source area on the left to the editing area on the right and double-click the icon to go to the Hudi job configuration page. Configure parameters based on the following table. For details about job parameters, see Creating a CDL Data Synchronization Job.
      Table 4 Source Hudi job parameters
      Example
      Link
      hudilink
      Interval
      10
      Table Info
      {"table1":[{"source.database":"db","source.tablename":"tabletest","target.tablename":"default.tabletest"}]}
      You do not need to configure the fields provided by Hudi. You only need to configure the service fields that need to be synchronized to ClickHouse.
    2. Click OK. The Hudi job parameters are configured.
  7. Configure ClickHouse job parameters.
    1. On the Job Management page, drag the clickhouse icon on the left to the editing area on the right and double-click the icon to go to the ClickHouse job configuration page. Configure parameters based on the following table. For details about job parameters, see Creating a CDL Data Synchronization Job.
      Table 5 ClickHouse job parameters
      Example
      Link
      cklink
      Query Timeout
      60000
      Batch Size
      100
    2. Click OK.
  8. Drag the two icons to associate the job parameters and click Save. The job configuration is complete.
  9. In the job list on the Job Management page, locate the created job, click Start in the Operation column, and wait until the job is started.
    Check whether the data transmission takes effect, for example, insert data into the Hudi table and view the content of the file imported to ClickHouse.
