On this page
Synchronizing Data from Hudi to DWS Using CDL
This section describes how to import data from Hudi to DWS by using the CDLService web UI of a cluster with Kerberos authentication enabled in MRS 3.2.0.
  • The CDL and Hudi services have been installed in a cluster and are running properly.
  • The prerequisites for the DWS database have been met. For details, see Prerequisites for the DWS database.
  • You have created a human-machine user, for example, cdluser, added the user to user groups cdladmin (primary group), hadoop, kafka, and supergroup, and associated the user with the System_administrator role on FusionInsight Manager.
  1. Log in to FusionInsight Manager as user cdluser (change the password upon your first login), choose Cluster > Services > CDL, and click the link next to CDLService UI to go to the CDLService web UI.
  2. Choose Link Management and click Add Link. In the displayed dialog box, set parameters for adding the dws and hudi links by referring to the following tables. Creating a CDL Database Connection describes the data link parameters.
    Table 1 DWS data link parameters
    Example
    Link Type
    dws
    Name
    dwstest
    Host
    10.10.10.10
    Port
    8000
    DB Name
    dwsdb
    User
    dbuser
    Password
    Password of the dbuser user
    Table 2 Hudi data link parameters
    Example
    Link Type
    hudi
    Name
    hudilink
    Storage Type
    hdfs
    Auth KeytabFile
    /opt/Bigdata/third_lib/CDL/user_libs/cdluser.keytab
    Principal
    cdluser
    xxx
  3. After the parameters are configured, click Test to check whether the data link is normal.
    After the test is successful, click OK.
  4. (Optional) Choose ENV Management and click Add Env. In the displayed dialog box, configure the parameters based on the following table.
    Table 3 Parameters for adding an ENV
    Example Value
    Name
    test-env
    Driver Memory
    1 GB
    Type
    spark
    Executor Memory
    1 GB
    Executor Cores
    Number Executors
    Queue
    Click OK.
  5. Choose Job Management > Data synchronization task and click Add Job. In the displayed dialog box, set parameters and click Next.
    Parameters are as follows.
    Example
    Name
    job_huditodws
    Desc
  6. Configure Hudi job parameters.
    1. On the Job Management page, drag the hudi icon in the Source area on the left to the editing area on the right and double-click the icon to go to the Hudi job configuration page. Configure parameters based on the following table. For details about job parameters, see Creating a CDL Data Synchronization Job.
      Table 4 Source Hudi job parameters
      Example
      Link
      hudilink
      Interval
      10
      Table Info
      {"table1":[{"source.database":"dwsdb","source.tablename":"tabletest","target.tablename":"tabletest"}]}
    2. Click OK. The Hudi job parameters are configured.
  7. Configure DWS job parameters.
    1. On the Job Management page, drag the dws icon on the left to the editing area on the right and double-click the icon to go to the DWS job configuration page. Configure parameters based on the following table. For details about job parameters, see Creating a CDL Data Synchronization Job.
      Table 5 DWS job parameters
      Example
      Link
      dwstest
      Query Timeout
      180000
      Batch Size
      10
      • Data can be synchronized from Hudi to GaussDB(DWS) only when both Hudi and GaussDB(DWS) contain the precombine field.
      • GaussDB(DWS) tables must contain the precombine field and the primary key.
      • By default, the Hudi built-in field _hoodie_event_time is used. If this field is not used, enable.sink.precombine must be specified. An example is as follows:
    2. Click OK.
  8. Drag the two icons to associate the job parameters and click Save. The job configuration is complete.
  9. In the job list on the Job Management page, locate the created job, click Start in the Operation column, and wait until the job is started.
    Check whether the data transmission takes effect, for example, insert data into the Hudi table and view the content of the file imported to DWS.
