Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Flink/ Creating a FlinkServer Job/ Creating a FlinkServer Job to Interconnect with a GaussDB(DWS) Table
Updated on 2024-12-13 GMT+08:00
This section applies to MRS 3.2.0 and to MRS 3.3.1.
FlinkServer can interconnect with GaussDB(DWS) 8.1.x or later. This section describes the DDL definitions when GaussDB(DWS) serves as source tables, sink tables, and dimension tables, as well as the WITH parameter and code examples used during table creation, and describes how to perform operations on the FlinkServer job management page. The following table lists the mapping between Flink SQL and GaussDB(DWS) data types.
In this example, FlinkServer and Kafka in security mode are used to interconnect with GaussDB(DWS) in security mode.
NOTICE:
When "FlinkSQL" is displayed in the command output on the FlinkServer web UI, the password field in the SQL statement is left blank to meet security requirements. Before you submit a job, manually enter the password.
Table 1 Mappings Between Flink SQL and GaussDB(DWS) Data Types
Flink SQL Data Type
BOOLEAN
BOOLEAN
TINYINT
SMALLINT
SMALLINT(INT2)
SMALLSERIAL(SERIAL2)
INTEGER
INTEGER
SERIAL
BIGINT
BIGINT
BIGSERIAL
FLOAT
REAL
FLOAT4
DOUBLE
DOUBLE
FLOAT8
CHAR
CHAR(n)
VARCHAR
VARCHAR(n)
DATE
DATE
TIMESTAMP
TIMESTAMP[(p)] [WITHOUT TIME ZONE]
DECIMAL
NUMERIC[(p[,s])]
DECIMAL[(p[,s])]
  • The cluster where FlinkServer is deployed must be able to communicate with the cluster where GaussDB(DWS) is deployed. The AZ, VPC, and security group configurations of the two clusters must be the same.
  • Cluster where FlinkServer resides (security mode):
    • HDFS, YARN, Kafka, ZooKeeper, and Flink have been installed in the cluster.
    • The client that contains the Kafka service has been installed, for example, in the /opt/client directory.
    • You have created a user with the FlinkServer Admin Privilege (for example, flinkuser) for accessing the Flink web UI by referring to Creating a FlinkServer Role.
  • Cluster of the GaussDB(DWS) to be interconnected (security mode):
    Run the following commands to connect to the database and create a table for receiving data:
    gsql -d postgres -h IP -U username –p port -W password –r
    • postgres indicates the name of the database to be connected.
    • IP: indicates the IP address of the GaussDB(DWS) cluster. If a public network address is used for connection, set this parameter to the public network domain name. If a private network address is used for connection, set this parameter to the private network domain name. If an ELB is used for connection, set this parameter to the ELB address.
    • username and password indicate the username and password for connecting to the database. Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
    • port: indicates the port number of the Coordinator. Replace it with the actual port number. You can run the gs_om -t status --detail command to query the Coordinator data path and view the port number in the postgresql.conf file in the path.
    Create an empty table for receiving data, for example, customer_t1.
    CREATE TABLE customer_t1
        c_customer_sk             INTEGER,
        c_customer_name           VARCHAR(32)
    with (orientation = column,compression=middle)
    distribute by hash (c_customer_name);
GaussDB as a Sink Table
  1. Log in to Manager as user flinkuser and choose Cluster > Services > Flink. In the Basic Information area, click the link next to Flink WebUI to access the Flink web UI.
  2. Create a Flink SQL job by referring to Creating a FlinkServer Job. On the job development page, configure the job parameters as follows and start the job.
    In Basic Parameter, select Enable CheckPoint, set Time Interval(ms) to 60000, and retain the default value for Mode.
    CREATE TABLE MyUserTable(
    ) WITH(
      'connector' = 'jdbc',
      'url'='jdbc:gaussdb://IP address of the GaussDB server:Database port number/postgres',
      'table-name' = 'customer_t1',--If table customer_t1 is created in schema base, the configuration rule is 'table-name' = 'base"."customer_t1'.
      'username' = 'username',--Username for logging in to the GaussDB(DWS) database
      'password'='password'--Password for connecting to the GaussDB(DWS) database. You need to specify the password when submitting the job.
      'write.mode' = 'upsert',--When data is written in upsert mode, you can set whether to ignore null values. (applicable to MRS 3.3.0 and later versions)
      'ignoreNullWhenUpsert' = 'false'--true indicates that null values are ignored, and false indicates that null values are not ignored and written to the database.
    CREATE TABLE KafkaSource (
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'customer_source',
      'properties.bootstrap.servers' = 'Service IP address of the Kafka Broker instance:Kafka port number',
      'properties.group.id' = 'testGroup',
      'scan.startup.mode' = 'latest-offset',
      'value.format' = 'csv',
      'properties.sasl.kerberos.service.name' = 'kafka',  --Delete this parameter if the cluster where FlinkServer resides is in non-security mode.
      'properties.security.protocol' = 'SASL_PLAINTEXT',  --Delete this parameter if the cluster where FlinkServer resides is in non-security mode.
      'properties.kerberos.domain.name' = 'hadoop.System domain name'  --Delete this parameter if the cluster where FlinkServer resides is in non-security mode.
    Insert into
      MyUserTable
    select
    from
      KafkaSource;
    • The Kafka port can be:
      • Value of sasl.port when Authentication Mode of the cluster is Security Mode, 21007 by default.
      • Value of port when Authentication Mode of the cluster is Normal Mode, 9092 by default. If the port number is set to 9092, set allow.everyone.if.no.acl.found to true. The procedure is as follows:
        Log in to FusionInsight Manager and choose Cluster > Services > Kafka. On the page that is displayed, click the Configurations tab then the All Configurations sub-tab. On the displayed page, search for allow.everyone.if.no.acl.found, set it to true, and click Save.
    • properties.group.id indicates the Kafka user group ID. This parameter is mandatory when Kafka functions as the source.
    • System domain name: You can log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain.
  3. On the job management page, check whether the job is in the Running status.
  4. Execute the following commands to view the topic and write data to Kafka. For details, see Managing Messages in Kafka Topics.
    ./kafka-topics.sh --list --zookeeper Service IP address of the ZooKeeper quorumpeer instance:Port number of the ZooKeeper client/kafka
    sh kafka-console-producer.sh --broker-list IP address of the node where Kafka instances reside:Kafka port number --topic Topic name --producer.config Client directory/Kafka/kafka/config/producer.properties
    In this example, the topic name is customer_source.
    sh kafka-console-producer.sh --broker-list IP address of the node where the Kafka instance is deployed:Kafka port number --topic customer_source --producer.config /opt/client/Kafka/kafka/config/producer.properties
    Enter the message content.
    3,zhangsan
    4,wangwu
    8,zhaosi
    Press Enter to send the message.
    • Service IP address of the ZooKeeper quorumpeer instance:
      Log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. On the page that is displayed, click the Instance tab and view the service IP addresses of all nodes where the quorumpeer instances reside.
    • Port number of the ZooKeeper client:
      Log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. On the page that is displayed, click the Configurations tab and check the value of clientPort.
  5. Log in to the GaussDB client and run the following command to check whether data has been sent to the sink table:
    Select * from customer_t1;
GaussDB as a Source Table
  2. Create a Flink SQL job by referring to Creating a FlinkServer Job. On the job development page, configure the job parameters and start the job.
    In Basic Parameter, select Enable CheckPoint, set Time Interval(ms) to 5000, and retain the default value for Mode.
      --GaussDB functions as a source table.
    ) WITH(
      'username' = 'username ',
      'password' = 'password '
    CREATE TABLE KafkaSink (
      -- Kafka functions as a sink table.
    ) WITH (
      'topic' = 'customer_sink',
    Insert into
      KafkaSink
    select
    from
      MyUserTable;
  4. Run the following command to check whether data is received in the sink table, that is, check whether data is properly written to the Kafka topic. For details, see Managing Messages in Kafka Topics.
    sh kafka-console-consumer.sh --topic customer_sink --bootstrap-server IP address of the node where the Kafka instance is deployed:Kafka port number --consumer.config /opt/client/Kafka/kafka/config/ consumer.properties
GaussDB as a Dimension Table
kafkaSource is used as the fact table, customer_t2 is used as the dimension table, and the result is written to kafkaSink.
  1. Create dimension table customer_t2 on the GaussDB client. An example of the table creation statement is as follows:
    CREATE TABLE customer_t2(
    c_customer_sk INTEGER PRIMARY KEY,
    c_customer_age INTEGER,
    c_customer_address VARCHAR(32)
    )DISTRIBUTE BY HASH(c_customer_sk);
    INSERT INTO customer_t2 VALUES(1,18,'city a');
    INSERT INTO customer_t2 VALUES(2,14,'city b');
    INSERT INTO customer_t2 VALUES(3,16,'city c');
    INSERT INTO customer_t2 VALUES(4,24,'city d');
    INSERT INTO customer_t2 VALUES(5,32,'city e');
    INSERT INTO customer_t2 VALUES(6,27,'city f');
    INSERT INTO customer_t2 VALUES(7,41,'city a');
    INSERT INTO customer_t2 VALUES(8,35,'city h');
    INSERT INTO customer_t2 VALUES(9,16,'city j');
  2. Log in to Manager as user flinkuser and choose Cluster > Services > Flink. In the Basic Information area, click the link next to Flink WebUI to access the Flink web UI.
  3. Create a Flink SQL job by referring to Creating a FlinkServer Job. On the job development page, configure the job parameters and start the job.
      -- Kafka as a source table
      c_customer_name VARCHAR(32),
      proctime as proctime()
    ) WITH (
      -- Kafka as a sink table
    ) WITH (
    CREATE TABLE MyUserTable (
      -- GaussDB as a dimension table
    ) WITH (
      'table-name' = 'customer_t2',
    INSERT INTO
      KafkaSink
    SELECT
      t.c_customer_sk,
      t.c_customer_name,
      d.c_customer_age,
      d.c_customer_address
    FROM
      KafkaSource as t
      JOIN MyUserTable FOR SYSTEM_TIME AS OF t.proctime as d ON t.c_customer_sk = d.c_customer_sk;
  4. Run the following command to check whether data is received in the sink table, that is, check whether data is properly written to the Kafka topic after 5 is performed. For details, see Managing Messages in Kafka Topics.
  5. View the topic and write data to the Kafka topic by referring to Managing Messages in Kafka Topics. After the data is written, view the execution result in the window in 4.
    • IP address of the ZooKeeper quorumpeer instance
      To obtain the IP addresses of all ZooKeeper quorumpeer instances, log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. On the displayed page, click Instance and view the IP addresses of all the hosts where the quorumpeer instances locate.
      Log in to FusionInsight Manager and choose Cluster > Service > ZooKeeper. On the displayed page, click Configurations and check the value of clientPort.
    3,zhangsan
    5,zhaosi
    1,xiaoming
    2,liuyang
    7,liubei
    10,guanyu
    20,zhaoyun
    Press Enter to send the message. The output in the kafka-console-consumer window in 4 is as follows:
    3,zhangsan,16,city c
    5,zhaosi,32,city e
    1,xiaoming,18,city a
    2,liuyang,14,city b
    7,liubei,41,city a
