Concurrency in the Hudi Schema Evolution
  When creating a table, you need to set hoodie.cleaner.policy.failed.writes to LAZY. Otherwise, rollback will be triggered when concurrent submission operations are performed.
DDL Concurrency
        DDL Operation  |
        add  |
        rename  |
        change type  |
        change comment  |
        drop  |
        add  |
        Y  |
        Y  |
        Y  |
        Y  |
        Y  |
        rename  |
        Y  |
        Y  |
        Y  |
        Y  |
        Y  |
        change type  |
        Y  |
        Y  |
        Y  |
        Y  |
        Y  |
        change comment  |
        Y  |
        Y  |
        Y  |
        Y  |
        Y  |
        drop  |
        Y  |
        Y  |
        Y  |
        Y  |
        N  |
   When performing DDL operations on the same column concurrently, pay attention to the following:
- Multiple drop operations cannot be concurrently performed at a time on the same column. Only the first drop operation can be successfully performed and then exception message "java.lang.UnsupportedOperationException: cannot evolution schema implicitly, the column for which the update operation is performed does not exist." is thrown.
 - When drop, rename, change type, and change comment operations are concurrently performed, drop operations must be executed the last. Otherwise, only drop and operations before drop can be performed, and exception message "java.lang.UnsupportedOperationException: cannot evolution schema implicitly, the column for which the update operation is performed does not exist." is reported when operations after drop are performed.
DDL and DML Concurrency
        DDL Operation  |
        insert into  |
        update  |
        delete  |
        set/reset  |
        add  |
        Y  |
        Y  |
        Y  |
        Y  |
        rename  |
        N  |
        N  |
        Y  |
        N  |
        change type  |
        N  |
        N  |
        Y  |
        N  |
        change comment  |
        Y  |
        Y  |
        Y  |
        Y  |
        drop  |
        N  |
        N  |
        Y  |
        N  |
   Exception message "cannot evolution schema implicitly, actions such as rename, delete, and type change were found" is thrown when unsupported DDL or DML operations are performed concurrently.
