Migrating Data Between Kafka Nodes
You can run Kafka client commands to migrate data between partitions on a node without stopping services. You can also use the Kafka UI to migrate partitions.
- The MRS cluster administrator has understood service requirements and prepared a Kafka user (belonging to the kafkaadmin group. It is not required for the normal mode.).
- The Kafka client has been installed.
- The Kafka instance status and disk status are normal.
- Based on the current disk space usage of the partition to be migrated, ensure that the disk space will be sufficient after the migration.
Migrating Data Using the Kafka Client
- Log in as a client installation user to the node on which the Kafka client is installed.
- Run the following command to switch to the Kafka client installation directory, for example, /opt/kafkaclient:
cd /opt/kafkaclient
- Run the following command to set environment variables:
source bigdata_env
- Run the following command to authenticate the user (skip this step in normal mode):
kinit Component service user
- Run the following command to switch to the Kafka client directory:
cd Kafka/kafka/bin
- Run the following command to view the topic details of the partition to be migrated:
Security mode:
./kafka-topics.sh --describe --bootstrap-server IP address of the Kafkacluster:21007 --command-config ../config/client.properties --topic topic name
Normal mode:
./kafka-topics.sh --describe --bootstrap-server IP address of the Kafka cluster:21005 --command-config ../config/client.properties --topic Topic name
- Run the following command to query the mapping between Broker_ID and the IP address:
./kafka-broker-info.sh --zookeeper IP address of the ZooKeeper quorumpeer instance:ZooKeeper port number/kafka
Broker_ID IP_Address -------------------------- 4 192.168.0.100 5 192.168.0.101 6 192.168.0.102
- IP address of the ZooKeeper quorumpeer instance
To obtain IP addresses of all ZooKeeper quorumpeer instances, log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. On the displayed page, click Instance and view the IP addresses of all the hosts where the quorumpeer instances locate.
- Port number of the ZooKeeper client
Log in to FusionInsight Manager and choose Cluster > Service > ZooKeeper. On the displayed page, click Configurations and check the value of clientPort. The default value is 24002.
- Obtain the partition distribution and node information from the command output in 6 and 7, and create the JSON file for reallocation in the current directory. To migrate data in the partition whose Broker_ID is 6 to the /srv/BigData/hadoop/data1/kafka-logs directory, the required JSON configuration file is as follows:
{"partitions":[{"topic": "testws","partition": 2,"replicas": [6,5],"log_dirs": ["/srv/BigData/hadoop/data1/kafka-logs","any"]}],"version":1}
- topic indicates the topic name, for example, testws.
- partition indicates the topic partition.
- The number in replicas corresponds to Broker_ID.
- log_dirs indicates the path of the disk to be migrated. In this example, log_dirs of the node whose Broker_ID is 5 is set to any, and that of the node whose Broker_ID is 6 is set to /srv/BigData/hadoop/data1/kafka-logs. Note that the path must correspond to the node.
- Run the following command to perform reallocation:
Security mode:
./kafka-reassign-partitions.sh --bootstrap-server Service IP address of Broker:21007 --command-config ../config/client.properties --reassignment-json-file Path of the JSON file compiled in 8 --execute
Normal mode:
./kafka-reassign-partitions.sh --bootstrap-server Service IP address of Broker:21005 --command-config ../config/client.properties --reassignment-json-file Path of the JSON file compiled in 8 --execute
If message "Successfully started reassignment of partitions" is displayed, the execution is successful.
Migrating Partitions Using KafkaUI (Versions earlier than MRS 3.5.0)
- Access the Kafka UI.
- Log in to FusionInsight Manager as a user who has the permission to access the Kafka UI and choose Cluster > Services > Kafka.
If you need to perform related operations on the page, for example, creating a topic, you need to grant related permissions to the user. For details, see Kafka User Permissions.
- On the right of KafkaManager WebUI, click the URL to access Kafka UI.
- Click Generate assignment. The Generate Partition Assignments page is displayed.
- In the Brokers area, select Broker ID to which the topic is to be re-assigned.
- Click Generate Partition Assignments to generate a partition migration solution.
- Click Run assignment to migrate a partition.
Migrating Partitions Using KafkaUI (Versions later than MRS 3.5.0)
- In the Brokers area, select brokers to which the topic is to be re-assigned.
- In the search box, search for the topic and partition to be migrated.
- The Partition column displays the topics to be migrated. The naming rule is Topic name-Partitioned index.
- The Replicas column displays the broker IDs where the topic partition is located.
- Click Generate Partition Assignments to generate a partition migration plan.
- Throttle: You can configure the flow control parameter for partition migration. If you leave it unconfigured, the rate will not be limited, as the default value is 0.
- Target Replicas: automatically generated partition migration plan, which can be manually modified. The format is Broker ID 1,Broker ID 2.
- Operation: You can delete topics that do not need to be migrated.
- Click Run assignment to execute the partition migration plan.
- Click Current Reassign Status to view the execution status of the current partition migration plan.
- Click Modify Reassignment Throttle to modify flow control parameters for zone migration.
- Click Cancel to cancel all partition migration plans that are being executed.
