Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Hudi/ Common Issues About Hudi/ Hudi Fails to Write Decimal Data with Lower Precision
Updated on 2026-06-27 GMT+08:00
Question
Decimal data is initially written to a Hudi table using the BULK_INSERT command. Then when data is subsequently written using UPSERT, the following error is reported:
java.lang.UnsupportedOperationException: org.apache.parquet.avro.AvroConverters$FieldFixedConverter
Answer
Cause:
The Hudi table contains decimal data.
The initial BULK_INSERT operation uses Spark classes to write Parquet files. However, Spark handles decimal data differently depending on its precision.
When data is written using the UPSERT command, Hudi uses the Avro-compliant class for writing Parquet files, which is incompatible with the Spark class.
Solutions:
When executing the BULK_INSERT command, set hoodie.datasource.write.row.writer.enable to false to enable Hoodie to use the Avro-compliant class for writing Parquet files.
