Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Hudi/
        Hudi Schema Evolution/
        Hudi Schema Evolution and Syntax/
      RENAME
RENAME
Function
The ALTER TABLE ... RENAME command is used to change the table name.
Syntax
ALTER TABLE tableName RENAME TO newTableName
Parameter Description
        Parameter  |
        Description  |
        tableName  |
        Table name.  |
        newTableName  |
        New table name.  |
Example
ALTER TABLE table1 RENAME TO table2
Response
You can run the SHOW TABLES command to view the new table name.
   Parent topic: Hudi Schema Evolution and Syntax
