ALTER COLUMN
Function
The ALTER TABLE ... ALTER COLUMN command is used to change the attributes of a column, such as the column type and position.
Syntax
ALTER TABLE Table name ALTER
[COLUMN] col_old_name TYPE column_type
[FIRST|AFTER] column_name
Parameter Description
| Parameter | Description |
| tableName | Table name. |
| col_old_name | Name of the column to be altered. |
| column_type | Type of the target column. |
| column_name | New position to place the target column. For example, AFTER column_name indicates that the target column is placed after column_name. |
Example
- Changing the column type
ALTER TABLE table1 ALTER COLUMN a.b.c TYPE bigint
a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
The following changes on column types are supported:
- int => long/float/double/string/decimal
- long => float/double/string/decimal
- float => double/String/decimal
- From double to string or decimal
- From decimal to decimal or string
- From string to date or decimal
- From date to string
- Altering other attributes
ALTER TABLE table1 ALTER COLUMN a.b.c DROP NOT NULL ALTER TABLE table1 ALTER COLUMN a.b.c FIRST ALTER TABLE table1 ALTER COLUMN a.b.c AFTER x
Response
You can run the DESCRIBE command to view the modified column.
