Configuring Spark for Hudi Schema Evolution
Configure Hudi in Spark to enable schema evolution, allowing you to modify the table schema dynamically without recreating the entire table.
Notes and Constraints
- Schema evolution cannot be disabled once being enabled.
- This section applies only to MRS 3.2.0-LTS or earlier.
Configuring Hudi Schema Evolution
- Use Spark Beeline to configure Hudi schema evolution.
Log in to MRS Manager, choose Cluster > Services > Spark2x, and click Configurations and then All Configurations. Search for spark.sql.extensions in the search box and change its value of JDBCServer to org.apache.spark.sql.hive.FISparkSessionExtension,org.apache.spark.sql.hudi.HoodieSparkSessionExtension,org.apache.spark.sql.hive.CarbonInternalExtensions.
- To enable Hudi schema evolution using Spark SQL, run the following command before executing your SQL statements:
set hoodie.schema.evolution.enable=true
- To enable Hudi schema evolution using the API, set the following parameter in your DataFrame configuration:
hoodie.schema.evolution.enable -> true
