Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Hudi/
        Hudi SQL Syntax Reference/
        Hudi DDL Syntax/
      TRUNCATE TABLE
TRUNCATE TABLE
Function
This command is used to clear all data in a specific table.
Syntax
TRUNCATE TABLE tableIdentifier
Parameter Description
        Parameter  |
        Description  |
        tableIdentifier  |
        Table name.  |
Examples
truncate table h0_1;
System Response
Data in the table is cleared. You can run the QUERY statement to check whether data in the table has been deleted.
   Parent topic: Hudi DDL Syntax
