ALTER RENAME TABLE
This section applies only to MRS 3.2.0-LTS to MRS 3.3.1-LTS.
Function
This command is used to rename an existing table.
Syntax
ALTER TABLE oldTableName RENAME TO newTableName
Parameter Description
Parameter |
Description |
oldTableName |
Current name of the table |
new_table_name |
New name of the table |
Examples
alter table h0 rename to h0_1;
System Response
The table name is changed. You can run the SHOW TABLES command to display the new table name.
