Configuring Automatic Clearing of FlinkServer Job Residuals
If a Flink task stops unexpectedly, some directories may reside in the ZooKeeper and HDFS services. To delete the residual directories, set ClearUpEnabled to true.
- Log in to Manager.
- Choose Cluster > Services > Flink. On the displayed page, click the Configurations tab and then All Configurations, search for parameter ClearUpEnabled, and set it to true. For details about related parameters, see Table 1.
Table 1 Parameters for deleting the residual directories Parameter
Default Value
Value Range
ClearUpEnabled
Specifies whether to delete the residual directories. Set this parameter to true if residual directories need to be deleted; set it to false otherwise.
true
true and false
ClearUpPeriod
Specifies the period for deleting residual directories, in minutes.
1440
1440~2147483647
TrashDirectoryRetentionPeriod
Specifies the period for retaining residual directories, in minutes.
10080
10080~2147483647
- Click Save.
- This function deletes only the residual directories in the /flink_base directory of the ZooKeeper service and the /flink/recovery directory of the HDFS service. User-defined directories will not be deleted.
- This function does not delete the checkpoints directory of the HDFS service. You need to manually delete it.
