Uploading the Database Driver File
CDL is a simple and efficient real-time data integration service. It captures events from various OLTP databases and pushes them to Kafka. When creating a database connection on the CDLService Web UI, you can upload the database's driver file to the Web UI for unified management.
- You have obtained the driver JAR package of the database to be connected.
 - You have downloaded the driver package of the MySQL or Oracle data source from their respective official website. Table 1 lists the supported driver packages and their versions.
 - A user with the CDL management permission has been created for the cluster with Kerberos authentication enabled. For details, see CDL User Permission Management.
- Access the CDLService web UI as a user with the CDL management permissions or the admin user (for the cluster where Kerberos authentication is not enabled). For details, see Logging In to the CDLService WebUI.
 - Choose Driver Management and click Upload Driver. In the displayed dialog box, select the prepared database driver file and click Open.
 - On the Driver Management page, check whether the list of driver file names is displayed properly.
     - If a driver is no longer used or is mistakenly uploaded, click Delete to delete its driver file.
 - If there are a large number of driver files, you can enter a driver file name in the search box to quickly search for the desired driver file.
