Updated on 2025-08-22 GMT+08:00
Importing and Exporting Data Using the ClickHouse Client
This section describes the basic syntax and instructions for using the ClickHouse client to import and export file data.
Using the ClickHouse Client to Import and Export Data
  • Importing data in CSV format
    clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number --secure --format_csv_delimiter="CSV file delimiter" --query="INSERT INTO Table name FORMAT CSV" < Host path where the CSV file is stored
    Example
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 --secure --format_csv_delimiter="," --query="INSERT INTO testdb.csv_table FORMAT CSV" < /opt/data
    You need to create a table in advance.
  • Exporting data in CSV format
    Exporting data files in CSV format may cause CSV injection. Exercise caution when performing this operation.
    clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="SELECT * FROM Table name" > CSV file export path
    Example
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table" > /opt/test
  • Importing data in Parquet format
    cat Parquet file | clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="INSERT INTO Table name FORMAT Parquet"
    Example
    cat /opt/student.parquet | clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="INSERT INTO parquet_tab001 FORMAT Parquet"
  • Exporting data in Parquet format
    clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="select * from Table name FORMAT Parquet" > Parquet file export path
    Example
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="select * from test_table FORMAT Parquet" > /opt/student.parquet
  • Importing data in ORC format
    cat ORC file path | clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="INSERT INTO Table name FORMAT ORC"
    Example
    cat /opt/student.orc | clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="INSERT INTO orc_tab001 FORMAT ORC"
    # Data in the ORC file can be exported from HDFS. For example:
    hdfs dfs -cat /user/hive/warehouse/hivedb.db/emp_orc/000000_0_copy_1 | clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="INSERT INTO orc_tab001 FORMAT ORC"
  • Exporting data in ORC format
    clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="select * from Table name FORMAT ORC" > ORC file export path
    Example
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="select * from csv_tab001 FORMAT ORC" > /opt/student.orc
  • Importing data in JSON format
    INSERT INTO Table name FORMAT JSONEachRow JSON string 1 JSON string 2
    Example
    INSERT INTO test_table001 FORMAT JSONEachRow {"PageViews":5, "UserID":"4324182021466249494", "Duration":146,"Sign":-1} {"UserID":"4324182021466249494","PageViews":6,"Duration":185,"Sign":1}
  • Exporting data in JSON format
    clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="SELECT * FROM Table name FORMAT JSON|JSONEachRow|JSONCompact|..." > JSON file export path
    Example
    # Export JSON file.
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table FORMAT JSON" > /opt/test.json
    # Export json(JSONEachRow).
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table FORMAT JSONEachRow" > /opt/test_jsoneachrow.json
    # Export json(JSONCompact).
    clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table FORMAT JSONCompact" > /opt/test_jsoncompact.json
