Creating a FlinkServer Job to Interconnect with a Hudi Table
This section applies to MRS 3.1.2 or later.
This section describes how to interconnect FlinkServer with Hudi through Flink SQL jobs. When you use Flink SQL to read data from or write data to Hudi, the TINYINT, SMALLINT, and TIME types cannot be defined.
Table 1 lists the read and write operations supported by Flink on Hudi COW and MOR tables.
- The HDFS, Yarn, Flink, and Hudi services have been installed in a cluster.
- The client that contains the Hudi service has been installed, for example, in the /opt/client directory.
- Flink 1.12.2 or later and Hudi 0.9.0 or later are required.
- You have created a user (for example, flink_admin) with FlinkServer administrator permissions for accessing the Flink web UI. For details, see Creating a FlinkServer Role. The user has been added to the hadoop, hive, and kafkaadmin user groups and granted the Manager_administrator role.
Creating a Job
- Log in to Manager as user flink_admin and choose Cluster > Services > Flink. In the Basic Information area, click the link on the right of Flink WebUI to access the Flink web UI.
- Create a Flink SQL stream job by referring to Creating a FlinkServer Job. On the job development page, configure the job as follows: Enter the SQL statement. After the SQL statement passes the verification, start the job. The following SQL examples are added as three jobs and run in sequence.
In Basic Parameter, select Enable CheckPoint, set Time Interval(ms) to 60000, and retain the default value for Mode.
- CheckPoint should be enabled on the Flink web UI because data is written to a Hudi table only when a Flink SQL job triggers CheckPoint. Adjust the CheckPoint interval based on service requirements. You are advised to set the interval to a large number.
- If the CheckPoint interval is too short, job exceptions may occur due to untimely data updates. It is recommended that the CheckPoint interval be configured at the minute level.
- Asynchronous compaction is required when a Flink SQL job writes an MOR table. For details about the parameter for controlling the compaction interval, visit Hudi official website https://hudi.apache.org/docs/configurations.html.
- Starting from MRS 3.2.1, Hudi table write operations use the Flink state index by default. To switch to the bucket index, add the following parameters to your write statement:
'index.type'='BUCKET', 'hoodie.bucket.index.num.buckets'='Number of buckets in each partition of a Hudi table' 'hoodie.bucket.index.hash.field'='recordkey.field'
- hoodie.bucket.index.num.buckets: Number of buckets in each partition of a Hudi table. Data in each partition is stored in each bucket in hash mode. This parameter cannot be modified after being set during table creation or data writing for the first time. Otherwise, an exception occurs during data update.
- hoodie.bucket.index.hash.field: Field for calculating the hash value during bucketing. The field must be a subset of the primary key. The default value is the primary key of the Hudi table. If this parameter is left blank, the default value recordkey.field is used.
- Starting from MRS 3.2.1, bucket indexing for a single Hudi table supports cross-engine writes between Flink and Spark.
- Job 1: This Flink SQL job writes data to an MOR table in streams.
CREATE TABLE stream_mor( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_mor', 'table.type' = 'MERGE_ON_READ', 'hoodie.datasource.write.recordkey.field' = 'uuid', 'write.precombine.field' = 'ts', 'write.tasks' = '4' ); CREATE TABLE kafka( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) WITH ( 'connector' = 'kafka', 'topic' = 'writehudi', 'properties.bootstrap.servers' = 'Service IP address of the Kafka Broker instance:Kafka port', 'properties.group.id' = 'testGroup1', 'scan.startup.mode' = 'latest-offset', 'format' = 'json', 'properties.sasl.kerberos.service.name' = 'kafka',--This parameter is not required for clusters in normal mode. Delete the comma (,) in the previous line. 'properties.security.protocol' = 'SASL_PLAINTEXT',--This parameter is not required for clusters in normal mode. 'properties.kerberos.domain.name' = 'hadoop.System domain name'--This parameter is not required for clusters in normal mode. ); insert into stream_mor select * from kafka;
- Job 2: This Flink SQL job writes data to a COW table in streams.
CREATE TABLE stream_write_cow( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_cow', 'hoodie.datasource.write.recordkey.field' = 'uuid', 'write.precombine.field' = 'ts', 'write.tasks' = '4' ); CREATE TABLE kafka( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) WITH ( 'connector' = 'kafka', 'topic' = 'writehudi', 'properties.bootstrap.servers' = 'Service IP address of the Kafka Broker instance:Kafka port', 'properties.group.id' = 'testGroup1', 'scan.startup.mode' = 'latest-offset', 'format' = 'json', 'properties.sasl.kerberos.service.name' = 'kafka',--This parameter is not required for clusters in normal mode. Delete the comma (,) in the previous line. 'properties.security.protocol' = 'SASL_PLAINTEXT',--This parameter is not required for clusters in normal mode. 'properties.kerberos.domain.name' = 'hadoop.System domain name'--This parameter is not required for clusters in normal mode. ); insert into stream_write_cow select * from kafka;
- Job 3: This Flink SQL job reads MOR and COW tables in streams, merges data, and outputs the merged data to Kafka. Verify the SQL statement of job 3 and start it after job 1 and job 2 are started and their status is running. Otherwise, an error message may be displayed during SQL verification, indicating that the Hudi table directory cannot be found.
CREATE TABLE stream_mor( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_mor', 'table.type' = 'MERGE_ON_READ', 'hoodie.datasource.write.recordkey.field' = 'uuid', 'write.precombine.field' = 'ts', 'read.tasks' = '4', 'read.streaming.enabled' = 'true', 'read.streaming.check-interval' = '5', 'read.streaming.start-commit' = 'earliest' ); CREATE TABLE stream_write_cow( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_cow', 'hoodie.datasource.write.recordkey.field' = 'uuid', 'write.precombine.field' = 'ts', 'read.tasks' = '4', 'read.streaming.enabled' = 'true', 'read.streaming.check-interval' = '5', 'read.streaming.start-commit' = 'earliest' ); CREATE TABLE kafka( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) WITH ( 'connector' = 'kafka', 'topic' = 'readhudi', 'properties.bootstrap.servers' = 'IP address of the Kafka Broker instance:Kafka port', 'properties.group.id' = 'testGroup1', 'scan.startup.mode' = 'latest-offset', 'format' = 'json', 'properties.sasl.kerberos.service.name' = 'kafka',--This parameter is not required for clusters in normal mode. Delete the comma (,) in the previous line. 'properties.security.protocol' = 'SASL_PLAINTEXT',--This parameter is not required for clusters in normal mode. 'properties.kerberos.domain.name' = 'hadoop.System domain name'--This parameter is not required for clusters in normal mode. ); insert into kafka select * from stream_mor union all select * from stream_write_cow;
- The Kafka Broker instance IP address and Kafka port number are as follows:
- To obtain the instance IP address, log in to FusionInsight Manager, choose Cluster > Services > Kafka, click Instances, and query the instance IP address on the instance list page.
- Value of sasl.port when Authentication Mode of the cluster is Security Mode. The default value is 21007.
- Value of port when Authentication Mode of the cluster is Normal Mode. The default value is 9092. If the port number is set to 9092, set allow.everyone.if.no.acl.found to true. The procedure is as follows:
Log in to FusionInsight Manager and choose Cluster > Services > Kafka. Click Configurations and then All Configurations. On the displayed page, search for allow.everyone.if.no.acl.found, set it to true, and click Save.
- System domain name: You can log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain.
- Execute the following script to write data to Kafka. For details, see Using Kafka to Produce Consumption Data.
sh kafka-console-producer.sh --broker-list IP address of the node where the Kafka instance is deployed:Kafka port --topic Topic name --producer.config Client directory/Kafka/kafka/config/producer.properties
In this example, the topic name is writehudi.
sh kafka-console-producer.sh --broker-list IP address of the node where the Kafka instance is deployed:Kafka port --topic writehudi --producer.config /opt/client/Kafka/kafka/config/producer.propertiesEnter the message content.{"uuid": "1","name":"a01","age":10,"ts":10,"p":"1"} {"uuid": "2","name":"a02","age":20,"ts":20,"p":"2"}Press Enter to send the message.
- Consumes Kafka topic data and reads the result of reading the Hudi table from Flink streams.
sh kafka-console-consumer.sh --bootstrap-server IP address of the node where the Kafka Broker instance is deployed:Kafka port --topic Topic name --consumer.config Client directory/Kafka/kafka/config/consumer.properties --from-beginning
In this example, the topic name is readhudi.
sh kafka-console-consumer.sh --bootstrap-server IP address of the node where the Kafka Broker instance is deployed:Kafka port --topic readhudi --consumer.config /opt/client/Kafka/kafka/config/consumer.properties --from-beginningThe read result is as follows (the sequence is not fixed):
{"uuid": "1","name":"a01","age":10,"ts":10,"p":"1"} {"uuid": "2","name":"a02","age":20,"ts":20,"p":"2"} {"uuid": "1","name":"a01","age":10,"ts":10,"p":"1"} {"uuid": "2","name":"a02","age":20,"ts":20,"p":"2"}
Precautions for Using Flink SQL Lookup Join Hudi
(The following content applies to MRS 3.5.0 or later.)
- The lookup.join.cache.ttl parameter is used to control the loading period of dimension table data. The default value is 60 minutes.
- Avoid using a Hudi table with more than 100,000 records as a dimension table, as the data will be loaded into the Flink TaskManager's heap memory.
- New and updated data in the dimension table will only be available for computation after the next loading cycle.
CREATE TABLE hudimor(
uuid VARCHAR(20),
name VARCHAR(10),
age INT,
ts INT,
`p` VARCHAR(20),
PRIMARY KEY (uuid) NOT ENFORCED
'path' = 'hdfs://hacluster/tmp/hudimor',
'lookup.join.cache.ttl' = '60min'
CREATE TABLE datagen(uuid varchar(20), proctime as PROCTIME()) WITH (
'connector' = 'datagen',
'rows-per-second' = '1'
CREATE TABLE blackhole (
uuid VARCHAR(20),
name VARCHAR(10),
age INT,
ts INT,
`p` VARCHAR(20)
) WITH ('connector' = 'blackhole');
insert into
blackhole
select
t1.uuid as uuid,
t2.name as name,
t2.age as age,
t2.ts as ts,
t2.p as p
FROM
datagen AS t1
left JOIN hudimor FOR SYSTEM_TIME AS OF t1.proctime AS t2 ON t1.uuid = t2.uuid; WITH Parameters
| Mode | Configuration Item | Mandatory | Default Value | Description |
| Read | read.tasks | No | 1 | The parallelism degree of the tasks for reading Hudi tables. The value is the same as the parallelism degree configured in the basic parameters on the FlinkServer job development page. |
| read.streaming.enabled | No | false | Whether to enable stream read. | |
| read.streaming.start-commit | No | By default, the latest commit is the start position. | Start commit time (closed interval) of incremental stream and batch consumption, in yyyyMMddHHmmss format. | |
| read.end-commit | No | By default, the latest commit is the end position. | End commit time (closed interval) of incremental stream and batch consumption, in yyyyMMddHHmmss format. | |
| Write | write.tasks | No | 1 | The parallelism degree of tasks for writing to Hudi tables. The value is the same as the parallelism degree configured in the basic parameters on the FlinkServer job development page. |
| index.bootstrap.enabled | No | false | Whether to enable index loading. If it is enabled, the latest data in the stored table is loaded to the state at a time. If incremental data needs to be synchronized to full data and there are offline Hoodie tables available, you can enable the index loading function to write data in real time and ensure that data is unique. | |
| write.index_bootstrap.tasks | No | 4 | If index loading is slow during job startup, consider increasing this parameter value. This improves efficiency afterward, but checkpoints will be blocked during the bootstrap phase. | |
| compaction.async.enabled | No | true | Whether to enable online compaction | |
| compaction.schedule.enabled | No | true | Whether to generate a compaction plan periodically. You are advised to enable this function even if online compaction is disabled. | |
| compaction.tasks | No | 10 | Parallelism of the tasks for compacting data in the Hudi table. | |
| index.state.ttl | No | 7D | Duration for storing indexes. The default value is 7 days. If the value is less than 0, indexes are stored permanently. Indexes are the core data structure for determining whether data is duplicate. For long-time updates, for example, updating data generated one month ago, you need to increase the value of this parameter. |
Synchronizing Metadata from Flink On Hudi to Hive
After this feature is enabled, Flink automatically creates a Hudi table on Hive and adds partitions to the Hudi table when writing data to it. Then services such as SparkSQL and Hive can read data from the Hudi table.
The metadata can be synchronized with either of the following methods. The JDBC mode is used as an example in the following steps.
- Synchronizing metadata to Hive in JDBC mode
CREATE TABLE stream_mor( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_mor', 'table.type' = 'MERGE_ON_READ', 'hive_sync.enable' = 'true', 'hive_sync.table' = 'Name of the table to be synchronized to Hive', 'hive_sync.db' = 'Name of the database to be synchronized to Hive', 'hive_sync.metastore.uris' = 'Value of hive.metastore.uris in the hive-site.xml file on the Hive client', 'hive_sync.jdbc_url' = 'Value of CLIENT_HIVE_URI in the component_env file on the Hive client' );
- hive_sync.jdbc_url: If the value of CLIENT_HIVE_URI in the Hive client file component_env contains \, delete \.
- To use the Hive style partitioning, add the following parameters:
- 'hoodie.datasource.write.hive_style_partitioning' = 'true'
- 'hive_sync.partition_extractor_class' = 'org.apache.hudi.hive.MultiPartKeysValueExtractor'
- Flink on Hudi synchronizes data to Hive. Hudi is case sensitive, while Hive is case insensitive. You are not advised to use uppercase letters in fields of Hudi tables. Otherwise, data may fail to be read or written.
- Synchronizing metadata to Hive in HMS mode
CREATE TABLE stream_mor( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_mor', 'table.type' = 'MERGE_ON_READ', 'hive_sync.enable' = 'true', 'hive_sync.table' = 'Name of the table to be synchronized to Hive', 'hive_sync.db' = 'Name of the database to be synchronized to Hive', 'hive_sync.mode' = 'hms', 'hive_sync.metastore.uris' = 'Value of hive.metastore.uris in the hive-site.xml file on the Hive client', 'properties.hive.metastore.kerberos.principal' = 'Value of hive.metastore.kerberos.principal in the hive-site.xml file on the Hive client' );
Methods with JDBC:
CREATE TABLE stream_mor2( uuid VARCHAR(20), name VARCHAR(10), age INT, ts INT, `p` VARCHAR(20) ) PARTITIONED BY (`p`) WITH ( 'connector' = 'hudi', 'path' = 'hdfs://hacluster/tmp/hudi/stream_mor2', 'table.type' = 'MERGE_ON_READ', 'hoodie.datasource.write.recordkey.field' = 'uuid', 'write.precombine.field' = 'ts', 'write.tasks' = '4', 'hive_sync.enable' = 'true', 'hive_sync.table' = 'Name of the table to be synchronized to Hive, for example, stream_mor2', 'hive_sync.db' = 'Name of the database to be synchronized to Hive, for example, default', 'hive_sync.metastore.uris' = 'Value of hive.metastore.uris in the hive-site.xml file on the Hive client', 'hive_sync.jdbc_url' = 'Value of CLIENT_HIVE_URI in the component_env file on the Hive client' ); CREATE TABLE datagen ( uuid varchar(20), name varchar(10), age int, ts INT, p varchar(20) ) WITH ( 'connector' = 'datagen', 'rows-per-second' = '1', 'fields.p.length' = '1' );insert into stream_mor2 select * from datagen;
- Wait for the Flink job to run for a period of time and continuously write the random test data generated by datagen to the Hudi table. You can click More > Job Monitoring to go to the native UI of Flink and view the job status.
- Log in to the node where the client is deployed, load environment variables, run the beeline command to log in to the Hive client, and run SQL statements to check whether the Hudi Sink table is successfully created on Hive and whether data can be read from the table.
cd /opt/hadoopclient source bigdata_env beeline desc formatted default.stream_mor2; select * from default.stream_mor2 limit 5; show partitions default.stream_mor2;
Field Comments in Flink SQL for Hudi Table Creation
Fields comments can be synchronized to Hive for Hudi tables created using the Hudi catalog.
CREATE CATALOG hoodie_catalog
WITH (
'type' = 'hudi',
'default-database' ='default',
'catalog.path' = 'hdfs:///tmp/',--Default storage path of the catalog table
'mode' = 'hms',
'cluster.name' ='hudiTest'
use catalog hoodie_catalog;
id int comment 'Primary key',
name VARCHAR(20) comment 'Name',
age INT comment 'Age',
`date` VARCHAR(20)
) PARTITIONED BY (`date`) WITH (
'path' = 'hdfs://hacluster/tmp/hudi_mor',--Hudi table storage path
'hoodie.datasource.write.recordkey.field' = 'id',
'write.precombine.field' = 'age',
'hoodie.datasource.write.hive_style_partitioning' = 'true',
'hive_sync.partition_extractor_class' = 'org.apache.hudi.hive.MultiPartKeysValueExtractor',
'index.type' = 'BUCKET',
'hoodie.bucket.index.num.buckets' = '8',
'write.tasks' = '8'
); What is your overall rating for this page?
