Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Hudi/ Common Issues About Hudi/ SchemaCompatibilityException Is Reported When Updated Data Is Written
Updated on 2026-06-27 GMT+08:00
Question
The following error is reported when data is written:
org.apache.hudi.exception.SchemaCompatibilityException: Unable to validate the rewritten record <record> against schema <schema>at org.apache.hudi.common.util.HoodieAvroUtils.rewrite(HoodieAvroUtils.java:215)
Answer
This error may occur if a schema contains some non-nullable field whose value is not present or is null.
You are advised to evolve schemas in backward compatible mode. Essentially, this means either you need to set each newly added field to null or to default values. In Hudi 0.5.1 and later versions, the troubleshooting is invalid if fields rely on default values.
