On this page
Show all
Synchronizing Hudi Table Data to Hive
You can run run_hive_sync_tool.sh to synchronize data in the Hudi table to Hive.
For example, run the following command to synchronize the Hudi table in the hdfs://hacluster/tmp/huditest/hudimor1_deltastreamer_partition directory on HDFS to the Hive table table hive_sync_test3 with unite, country, and state as partition keys:
run_hive_sync_tool.sh --partitioned-by unite,country,state --base-path hdfs://hacluster/tmp/huditest/hudimor1_deltastreamer_partition --table hive_sync_test3 --partition-value-extractor org.apache.hudi.hive.MultiPartKeysValueExtractor --support-timestamp
Table 1 Parameter description
Command
Mandatory or Not (Yes or No)
Default Value
--database
Specifies the Hive database name.
No
default
--table
Specifies the Hive table name.
Yes
--base-file-format
Specifies the file format (PARQUET or HFILE).
No
PARQUET
--user
Specifies the Hive username.
No
--pass
Specifies the Hive password.
No
--jdbc-url
Specifies the Hive JDBC connection URL.
No
--base-path
Specifies the storage path of the Hudi table to be synchronized.
Yes
--partitioned-by
Specifies the partition key.
No
Specifies the partition class. PartitionValueExtractor needs to be implemented. The partition value can be extracted from the HDFS path.
No
SlashEncodedDayPartitionValueExtractor
--assume-date-partitioning
Creates partitions in yyyy/mm/dd format to support backward compatibility.
No
false
--use-pre-apache-input-format
Use InputFormat in the com.uber.hoodie package to replace the one in the org.apache.hudi package. Do not use this command except for migrating projects from com.uber.hoodie to org.apache.hudi.
No
false
--use-jdbc
Uses Hive JDBC connection.
No
true
--auto-create-database
Specifies whether to automatically create a Hive database.
No
true
--skip-ro-suffix
Specifies whether to skip the read-optimized view with the _ro suffix during registration.
No
false
--use-file-listing-from-metadata
Specifies whether to obtain the file list from the Hudi metadata.
No
false
--verify-metadata-file-listing
Specifies whether to verify the file list in the Hudi metadata based on the file system.
No
false
--help/-h
Specifies whether to display help information.
No
false
--support-timestamp
Specifies whether to convert TIMESTAMP_MICROS of INT64 to Hive timestamp.
No
false
--decode-partition
Specifies whether to decode the partition value if the partition is encoded during the write process.
No
false
--batch-sync-num
Specifies the number of Hive partitions to be synchronized in each batch.
No
1000
During Hive synchronization, if the table does not exist, an external table is created and partitions are added. If the table exists, check whether table schemas are different. If they are different, replace the table. Check whether new partitions exist. If new partitions exist, partitions are added accordingly.
Therefore, there are the following restrictions when Hive synchronization is used:
  • Fields can only be added to the schema and cannot be modified or deleted.
  • Partition directories can only be added but cannot be deleted.
  • Overwrite can only overwrite the Hudi table. The Hive table cannot be overwritten synchronously.
  • Do not use the timestamp type as the partition column when synchronizing a Hudi table to Hive.
