Spark on OBS Performance Tuning
In the scenario where a small number of requests are frequently sent from Spark on OBS to OBS, you can disable OBS monitoring to improve performance.
Configuration
- Install the Spark client.
For details, see Installing a Client.
- Log in to the Spark client node as the client installation user. Modify the following parameters in the Client installation directory/Spark/spark/conf/core-site.xml file on the Spark client.
Table 1 Parameter description Parameter
Default Value
fs.obs.metrics.switch
Specifies whether to report OBS monitoring metrics.
- true: enable
- false: disable
true
fs.obs.metrics.consumer
Specifies the processing mode of OBS monitoring metrics.
- org.apache.hadoop.fs.obs.metrics.OBSAMetricsProvider: indicates that OBS monitoring metrics are collected.
- org.apache.hadoop.fs.obs.DefaultMetricsConsumer: indicates that OBS monitoring metrics are not collected.
To use the OBS monitoring function, ensure that the function of reporting OBS monitoring metrics is enabled.
