Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using YARN/ Common Issues About Yarn/ Why Do Reduce Tasks Fail to Run in Some OSs After the Native Task Feature is Enabled?
Updated on 2026-06-27 GMT+08:00
Question
When -Dmapreduce.job.map.output.collector.class=org.apache.hadoop.mapred.nativetask.NativeMapOutputCollectorDelegator is executed to enable the Native Task feature during the running of MapReduce tasks that contain Reduce tasks, the tasks fail to run in some OSs, and the error message "version 'GLIBCXX_3.4.20' not found" is displayed in logs.
Answer
This issue occurs because the GLIBCXX version of the OS is outdated. As a result, the libnativetask.so.1.0.0 library required by this feature cannot be loaded, leading to task failures.
Workaround:
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Cluster > Services > Yarn > Configurations > All Configurations.
  3. In the navigation pane, choose ResourceManager(Role) > Customization.
  4. Add the following content to the resourcemanager.mapred-site.customized.configs parameter:
    • Name: Set it to mapreduce.job.map.output.collector.class.
    • Value: Set it to org.apache.hadoop.mapred.MapTask$MapOutputBuffer.
  5. Save the settings. Restart the expired service or instance for the configuration to take effect.
  6. After the modification is complete, download the client again or update the client configuration.
