Writing Data to Hudi Tables in Streams
Streaming writes to Hudi tables is performed using either HoodieDeltaStreamer or HoodieMultiTableDeltaStreamer.
- Streaming writes using HoodieDeltaStreamer
The HoodieDeltaStreamer utility provided by Hudi supports streaming writes. Alternatively, you can use Spark Streaming to write data using micro-batch processing. HoodieDeltaStreamer enables you to ingest data from various source types and write it into target Hudi tables. However, HoodieDeltaStreamer can only update one target table from a single source per execution. HoodieDeltaStreamer provides the following functions:
- Supports multiple data sources, such as Kafka and DFS.
- Manages checkpoints, rollback, and recovery to ensure exactly-once semantics.
- Supports user-defined transformations.
- Streaming writes using HoodieMultiTableDeltaStreamer: The HoodieMultiTableDeltaStreamer utility supports data ingestion from multiple source tables into one or more target Hudi tables.
Notes and Constraints
This section applies only to MRS 3.3.1-LTS or earlier.
Stream Write Using HoodieDeltaStreamer
Example: Prepare the configuration file kafka-source.properties.
#Hudi configuration hoodie.datasource.write.recordkey.field=id hoodie.datasource.write.partitionpath.field=age hoodie.upsert.shuffle.parallelism=100 #hive config hoodie.datasource.hive_sync.table=hudimor_deltastreamer_partition hoodie.datasource.hive_sync.partition_fields=age hoodie.datasource.hive_sync.partition_extractor_class=org.apache.hudi.hive.MultiPartKeysValueExtractor hoodie.datasource.hive_sync.use_jdbc=false hoodie.datasource.hive_sync.support_timestamp=true # Kafka Source topic hoodie.deltastreamer.source.kafka.topic=hudimor_deltastreamer_partition #checkpoint hoodie.deltastreamer.checkpoint.provider.path=hdfs://hacluster/tmp/huditest/hudimor_deltastreamer_partition # Kafka props # The kafka cluster we want to ingest from bootstrap.servers= xx.xx.xx.xx:xx auto.offset.reset=earliest #auto.offset.reset=latest group.id=hoodie-delta-streamer offset.rang.limit=10000
Run the following commands to specify the HoodieDeltaStreamer execution parameters (for details about the parameter configuration, visit the official website at https://hudi.apache.org/):
spark-submit --master yarn --jars /opt/hudi-java-examples-1.0.jar // Specify the Hudi jars directory required for Spark running. --driver-memory 1g --executor-memory 1g --executor-cores 1 --num-executors 2 --conf spark.kryoserializer.buffer.max=128m --driver-class-path /opt/client/Hudi/hudi/conf:/opt/client/Hudi/hudi/lib/*:/opt/client/Spark2x/spark/jars/*:/opt/hudi-examples-0.6.1-SNAPSHOT.jar:/opt/hudi-examples-0.6.1-SNAPSHOT-tests.jar // Specify the Hudi jars directory required by the Spark driver. --class org.apache.hudi.utilities.deltastreamer.HoodieDeltaStreamer spark-internal --props file:///opt/kafka-source.properties // Specify the configuration file. You need to set the configuration file path to the HDFS path when submitting tasks in yarn-cluster mode. --target-base-path /tmp/huditest/hudimor1_deltastreamer_partition // Specify the path of the Hudi table. --table-type MERGE_ON_READ // Specify the type of the Hudi table to be written. --target-table hudimor_deltastreamer_partition // Specify the Hudi table name. --source-ordering-field name // Specify the columns to be pre-combined in the Hudi table. --source-class org.apache.hudi.utilities.sources.JsonKafkaSource // Set the consumed data source to JsonKafkaSource. Specify source classes based on data sources. --schemaprovider-class com.huawei.bigdata.hudi.examples.DataSchemaProviderExample // Specify the schema required by the Hudi table. --transformer-class com.huawei.bigdata.hudi.examples.TransformerExample // Specify how to process the data obtained from the data source. Set this parameter based on service requirements. --enable-hive-sync // Enable Hive synchronization to synchronize the Hudi table to Hive. --continuous // Set the stream processing mode to continuous.
Stream Write Using HoodieMultiTableDeltaStreamer
HoodieMultiTableDeltaStreamer streaming write is available only in MRS 3.2.0 or later.
- The following example describes how to write data in two Kafka source tables to two Hudi tables.
Set the following parameters:
// Specify the target table. hoodie.deltastreamer.ingestion.tablesToBeIngested=Directory name.target table //Specify all source tables to specific destination tables. hoodie.deltastreamer.source.sourcesBoundTo.Destination table=Directory name.Source table 1,Directory name.Source table 2 // Specify the configuration file path of each source table. hoodie.deltastreamer.source.Directory name.Source table 1.configFile=Path 1 hoodie.deltastreamer.source.Directory name.Source table 2.configFile=Path 2 // Specify the recovery point of each source table. The format of the recovery point varies according to the source table type. For example, the recovery point format of the Kafka source is Topic name,Partition name:offset. hoodie.deltastreamer.current.source.checkpoint=Topic name,Partition name:offset // Specify the associated table (Hudi table) of each source table. If there are multiple associated tables, separate them with commas (,). hoodie.deltastreamer.source.associated.tables=hdfs://hacluster/....., hdfs://hacluster/..... // Specify the transform operation before the data in each source table is written to Hudi. Note that the columns to be written must be listed. Do not use select *. // <SRC> indicates the current source table and cannot be changed. hoodie.deltastreamer.transformer.sql=select field1,field2,field3,... from <SRC>
Spark submission command:
spark-submit \ --master yarn \ --driver-memory 1g \ --executor-memory 1g \ --executor-cores 1 \ --num-executors 5 \ --conf spark.driver.extraClassPath=/opt/client/Hudi/hudi/conf:/opt/client/Hudi/hudi/lib/*:/opt/client/Spark2x/spark/jars/* \ --class org.apache.hudi.utilities.deltastreamer.HoodieMultiTableDeltaStreamer /opt/client/Hudi/hudi/lib/hudi-utilities_2.12-*.jar \ --props file:///opt/hudi/testconf/sourceCommon.properties \ --config-folder file:///opt/hudi/testconf/ \ --source-class org.apache.hudi.utilities.sources.JsonKafkaSource \ --schemaprovider-class org.apache.hudi.examples.common.HoodieMultiTableDeltaStreamerSchemaProvider \ --transformer-class org.apache.hudi.utilities.transform.SqlQueryBasedTransformer \ --source-ordering-field col6 \ --base-path-prefix hdfs://hacluster/tmp/ \ --table-type COPY_ON_WRITE \ --target-table KafkaToHudi \ --enable-hive-sync \ --allow-fetch-from-multiple-sources \ --allow-continuous-when-multiple-sources
- When the source type is kafka source, the schema provider class specified by --schemaprovider-class needs to be developed by users.
- --allow-fetch-from-multiple-sources indicates that multi-source table writing is enabled.
- --allow-continuous-when-multiple-sources indicates that multi-source table continuous write is enabled. If this parameter is not set, the task ends after all source tables are written once.
sourceCommon.properties:
hoodie.deltastreamer.ingestion.tablesToBeIngested=testdb.KafkaToHudi hoodie.deltastreamer.source.sourcesBoundTo.KafkaToHudi=source1,source2 hoodie.deltastreamer.source.default.source1.configFile=file:///opt/hudi/testconf/source1.properties hoodie.deltastreamer.source.default.source2.configFile=file:///opt/hudi/testconf/source2.properties hoodie.datasource.write.keygenerator.class=org.apache.hudi.keygen.SimpleKeyGenerator hoodie.datasource.write.partitionpath.field=col0 hoodie.datasource.write.recordkey.field=primary_key hoodie.datasource.write.precombine.field=col6 hoodie.datasource.hive_sync.table=kafkatohudisync hoodie.datasource.hive_sync.partition_fields=col0 hoodie.datasource.hive_sync.partition_extractor_class=org.apache.hudi.hive.MultiPartKeysValueExtractor bootstrap.servers=192.168.34.221:21005,192.168.34.136:21005,192.168.34.175:21005 auto.offset.reset=latest group.id=hoodie-test
source1.properties:
hoodie.deltastreamer.current.source.name=source1 // Specify the name of a Kafka source table. hoodie.deltastreamer.source.kafka.topic=s1 hoodie.deltastreamer.current.source.checkpoint=s1,0:0,1:0 // Checkpoint of the source table when the task is started. The deltastreamer tasks resume from offset 0 of partition 0 and offset 0 of partition 1. // Specify the Hudi table to be joined with the source1 table. If the Hudi table has already been synchronized to Hive, you may skip this step and use the Hive table name directly in your SQL statement. hoodie.deltastreamer.source.associated.tables=hdfs://hacluster/tmp/huditest/tb_test_cow_par // <SRC> indicates the current source table, that is, source1. The value is fixed. hoodie.deltastreamer.transformer.sql=select A.primary_key, A.col0, B.col1, B.col2, A.col3, A.col4, B.col5, B.col6, B.col7 from <SRC> as A join tb_test_cow_par as B on A.primary_key = B.primary_key
source2.properties
hoodie.deltastreamer.current.source.name=source2 hoodie.deltastreamer.source.kafka.topic=s2 hoodie.deltastreamer.current.source.checkpoint=s2,0:0,1:0 hoodie.deltastreamer.source.associated.tables=hdfs://hacluster/tmp/huditest/tb_test_cow_par hoodie.deltastreamer.transformer.sql=select A.primary_key, A.col0, B.col1, B.col2, A.col3, A.col4, B.col5, B.col6, B.col7 from <SRC> as A join tb_test_cow_par as B on A.primary_key = B.primary_key
- The following example describes how to write data in two Hudi tables to one Hudi table
spark-submit \ --master yarn \ --driver-memory 1g \ --executor-memory 1g \ --executor-cores 1 \ --num-executors 2 \ --conf spark.driver.extraClassPath=/opt/client/Hudi/hudi/conf:/opt/client/Hudi/hudi/lib/*:/opt/client/Spark2x/spark/jars/* \ --class org.apache.hudi.utilities.deltastreamer.HoodieMultiTableDeltaStreamer /opt/client/Hudi/hudi/lib/hudi-utilities_2.12-*.jar \ --props file:///opt/testconf/sourceCommon.properties \ --config-folder file:///opt/testconf/ \ --source-class org.apache.hudi.utilities.sources.HoodieIncrSource \ // Specify that the source table is a Hudi table, which can only be COW. --payload-class org.apache.hudi.common.model.OverwriteNonDefaultsWithLatestAvroPayload \ // Specify a payload, which determines how the original value is changed to a new value. --transformer-class org.apache.hudi.utilities.transform.SqlQueryBasedTransformer \ // Specify a transformer class. If the schema of the source table is different from that of the target table, the source table data can be written to the target table only after being transformed. --source-ordering-field col6 \ --base-path-prefix hdfs://hacluster/tmp/ \ // Path for saving the destination tables --table-type MERGE_ON_READ \ // Type of the destination table, which can be COW or MOR. --target-table tb_test_mor_par_300 \ // Specify the name of the target table. When you write data in multiple source tables to a target table, the name of the target table must be specified. --checkpoint 000 \ // Specify a checkpoint (commit timestamp), which indicates that Delta Streamer is restored from this checkpoint. 000 indicates that Delta Streamer is restored from the beginning. --enable-hive-sync \ --allow-fetch-from-multiple-sources \ --allow-continuous-when-multiple-sources \ --op UPSERT // Specify the write type.
- If the source is set to HoodieIncrSource, --schemaprovider-class does not need to be specified.
- If transformer-class is set to SqlQueryBasedTransformer, you can use SQL queries to convert the data structure of the source table to that of the destination table.
file:///opt/testconf/sourceCommon.properties:
# Common properties of source tables hoodie.deltastreamer.ingestion.tablesToBeIngested=testdb.tb_test_mor_par_300 // Specify a target table (common property) to which multiple source tables are written. hoodie.deltastreamer.source.sourcesBoundTo.tb_test_mor_par_300=testdb.tb_test_mor_par_100,testdb.tb_test_mor_par_200 //Specify multiple source tables. hoodie.deltastreamer.source.testdb.tb_test_mor_par_100.configFile=file:///opt/testconf/tb_test_mor_par_100.properties // Property file path of the source table tb_test_mor_par_100 hoodie.deltastreamer.source.testdb.tb_test_mor_par_200.configFile=file:///opt/testconf/tb_test_mor_par_200.properties //Property file path of the source table tb_test_mor_par_200 # Hudi write configurations shared by all source tables. The independent configurations of a source table need to be written to its property file. hoodie.datasource.write.keygenerator.class=org.apache.hudi.keygen.SimpleKeyGenerator hoodie.datasource.write.partitionpath.field=col0 hoodie.datasource.write.recordkey.field=primary_key hoodie.datasource.write.precombine.field=col6
# Configurations of the source table tb_test_mor_par_100 hoodie.deltastreamer.source.hoodieincr.path=hdfs://hacluster/tmp/testdb/tb_test_mor_par_100 // Path of the source table hoodie.deltastreamer.source.hoodieincr.partition.fields=col0 // Partitioning key of the source table hoodie.deltastreamer.source.hoodieincr.read_latest_on_missing_ckpt=false hoodie.deltastreamer.source.associated.tables=hdfs://hacluster/tmp/testdb/tb_test_mor_par_400 //Specify the table to be associated with the source table. hoodie.deltastreamer.transformer.sql=select A.primary_key, A.col0, B.col1, B.col2, A.col3, A.col4, B.col5, A.col6, B.col7 from <SRC> as A join tb_test_mor_par_400 as B on A.primary_key = B.primary_key //This configuration takes effect only when transformer-class is set to SqlQueryBasedTransformer.
file:///opt/testconf/tb_test_mor_par_200.properties# Configurations of the source table tb_test_mor_par_200 hoodie.deltastreamer.source.hoodieincr.path=hdfs://hacluster/tmp/testdb/tb_test_mor_par_200 hoodie.deltastreamer.source.hoodieincr.partition.fields=col0 hoodie.deltastreamer.source.hoodieincr.read_latest_on_missing_ckpt=false hoodie.deltastreamer.source.associated.tables=hdfs://hacluster/tmp/testdb/tb_test_mor_par_400 hoodie.deltastreamer.transformer.sql=select A.primary_key, A.col0, B.col1, B.col2, A.col3, A.col4, B.col5, A.col6, B.col7 from <SRC> as A join tb_test_mor_par_400 as B on A.primary_key = B.primary_key //Convert the data structure of the source table to that of the destination table. If the source table needs to be associated with Hive, you can use the table name in the SQL query for association. If the source table needs to be associated with a Hudi table, you need to specify the path of the Hudi table first and then use the table name in the SQL query for association.
