Updated on 2026-06-27 GMT+08:00
Accessing the FlinkServer Web UI
After Flink is installed in an MRS cluster, you can connect to clusters and data as well as manage stream tables and jobs using the Flink web UI.
This section describes how to access the Flink web UI in an MRS cluster. Site trust must be added to the browser when you access Manager and the Flink web UI for the first time. Otherwise, the Flink web UI cannot be accessed.
  1. Log in to FusionInsight Manager as a user with FlinkServer Admin Privilege. Choose Cluster > Services > Flink.
    If Kerberos authentication has been enabled for your MRS cluster, create a role with the FlinkServer administrator permission or the application viewing and editing permission, and associate the role to the user. Then, you can access the Flink web UI. For details about how to create a role, see Creating a FlinkServer Role. The user must also have the necessary permissions to access related pages on MRS Manager, typically granted by assigning the System_administrator role.
  2. On the right of Flink WebUI, click the link to access the Flink web UI.
    Figure 1 Accessing the Flink Web UI
    The Flink web UI provides the following functions:
    • System management:
      • Cluster connection management allows you to create, view, edit, test, and delete a cluster connection.
      • Data connection management allows you to create, view, edit, test, and delete a data connection. Data connection types include HDFS and Kafka.
      • Application management allows you to create, view, and delete an application.
    • Stream table management allows you to create, view, edit, and delete a stream table.
    • Job management allows you to create, view, start, develop, edit, stop, and delete a job.
