Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using Ranger/
Changing the Ranger Data Source to LDAP for a Normal Cluster
Updated on 2025-07-16 GMT+08:00
By default, the Ranger data source of the security cluster can be accessed by FusionInsight Manager LDAP users. By default, the Ranger data source of a common cluster can be accessed by Unix users.
- The cluster is in normal mode.
- The Ranger component has been installed.
- Log in to FusionInsight Manager by referring to Accessing FusionInsight Manager, choose Cluster > Services > Ranger, click Configurations, and click All Configurations. Click UserSync(Role) and click Customization.
- In the ranger.usersync.config.expandor area, set ranger.usersync.sync.source to ldap and ranger.usersync.cookie.enabled to false, as shown in the following figure.
- In the upper right corner of the Ranger Dashboard page, click More and choose Synchronize Configuration.
- On the Ranger instance page, select the UserSync instance and choose More > Restart Instance.
- On the Dashboard page of the Ranger service, click RangerAdmin and choose Settings > Users/Groups/Roles to check whether LDAP users exist.
Parent topic: Using Ranger
