Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Oozie/
        Using Hue to Submit an Oozie Job/
      Submitting an Oozie HQL Script Using Hue
This section describes how to submit a Hive job on the Hue web UI.
- Access the Hue web UI. For details, see Accessing the Hue Web UI.
 - In the navigation tree on the left, click
 and choose Workflow to open the Workflow editor. - Click Documents, click
 to select a Hive script from the operation list, and drag it to the operation page. - In the HiveServer2 Script dialog box that is displayed, select the saved Hive script. For details about how to save the Hive script, see Using Hue to Execute HiveQL. Select a script and click Add.
 - Configure the Job XML, for example, to the HDFS path /user/admin/examples/apps/hive2/hive-site.xml. For details, see Submitting an Oozie Hive2 Job Using Hue.
 - Click
 in the upper right corner of the Oozie editor. - After the configuration is saved, click
, and submit the job.
    After the job is submitted, you can view the related contents of the job, such as the detailed information, logs, and processes, on Hue.
   Parent topic: Using Hue to Submit an Oozie Job
