Existing HBase Tables Cannot Be Searched Using Wildcards When HBase Permission Policies Are Configured
Question
When a Ranger access permission policy is added for HBase and wildcard characters are used to search for an existing HBase table in the policy, the table cannot be found. The following error is reported in /var/log/Bigdata/ranger/rangeradmin/ranger-admin-*log:
Caused by: javax.security.sasl.SaslException: No common protection layer between client and server at com.sun.security.sasl.gsskerb.GssKrb5Client.doFinalHandshake(GssKrb5Client.java:253) at com.sun.security.sasl.gsskerb.GssKrb5Client.evaluateChallenge(GssKrb5Client.java:186) at org.apache.hadoop.hbase.security.AbstractHBaseSaslRpcClient.evaluateChallenge(AbstractHBaseSaslRpcClient.java:142) at org.apache.hadoop.hbase.security.NettyHBaseSaslRpcClientHandler$2.run(NettyHBaseSaslRpcClientHandler.java:142) at org.apache.hadoop.hbase.security.NettyHBaseSaslRpcClientHandler$2.run(NettyHBaseSaslRpcClientHandler.java:138) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAs(Subject.java:422) at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1761) at org.apache.hadoop.hbase.security.NettyHBaseSaslRpcClientHandler.channelRead0(NettyHBaseSaslRpcClientHandler.java:138) at org.apache.hadoop.hbase.security.NettyHBaseSaslRpcClientHandler.channelRead0(NettyHBaseSaslRpcClientHandler.java:42) at org.apache.hbase.thirdparty.io.netty.channel.SimpleChannelInboundHandler.channelRead(SimpleChannelInboundHandler.java:105) at org.apache.hbase.thirdparty.io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:362)
Answer
The value of hbase.rpc.protection of the HBase service plug-in on Ranger must be the same as that of hbase.rpc.protection on the HBase server.
- Log in to the Ranger management page. For details, see Logging In to the Ranger Web UI.
- In the HBASE area on the home page, click the component plug-in name, for example, the
button of HBase. - Search for the configuration item hbase.rpc.protection and change its value to the value of hbase.rpc.protection on the HBase server.
- Click Save.
