Why Does Metadata Still Exist When the HDFS Data Directory of the Hive Table Is Deleted by Mistake?
Question
The HDFS data directory of the Hive table is deleted by mistake, but the metadata still exists. As a result, an error is reported during task execution.
Answer
This is an exception caused by misoperation. You need to manually delete the metadata of the corresponding table and try again.
Example:
Run the following command to log in to the Hive metabase:
source ${BIGDATA_HOME}/FusionInsight_BASE_xxx/install/FusionInsight-dbservice-2.7.0/.dbservice_profile
gsql -p 20051 -U hive -d hivemeta -W Password for the database user hivemeta
Manually delete the metadata of the corresponding table:
delete from tbls where tbl_id='xxx';
