On this page
Adapting to the Third-party JDK When Ranger Is Used
Updated on 2024-12-13 GMT+08:00
When Ranger is used as the permission management service of Spark SQL, the certificate in the cluster is required for accessing RangerAdmin. If you use a third-party JDK instead of the JDK or JRE in the cluster, RangerAdmin fails to be accessed. As a result, the Spark application fails to be started.
In this scenario, you need to perform the following operations to import the certificate in the cluster to the third-party JDK or JRE.
Configuration Method
  1. Run the following command to export the certificate from the cluster:
    1. Install the cluster client. Assume that the installation path is /opt/client.
    2. Run the following command to switch to the client installation directory:
      cd /opt/client
    3. Run the following command to configure environment variables:
      source bigdata_env
    4. Generate the certificate file.
      keytool -export -alias fusioninsightsubroot -storepass changeit -keystore /opt/client/JRE/jre/lib/security/cacerts -file fusioninsightsubroot.crt
  2. Import the certificate in the cluster to the third-party JDK or JRE.
    Copy the fusioninsightsubroot.crt file generated in 1 to the third-party JRE node, set the JAVA_HOME environment variable of the node, and run the following command to import the certificate:
    keytool -import -trustcacerts -alias fusioninsightsubroot -storepass changeit -file fusioninsightsubroot.crt -keystore MY_JRE/lib/security/cacerts
    MY_JRE indicates the installation path of the third-party JRE. Change it based on the site requirements.
