Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using ZooKeeper/ Common Issues About ZooKeeper/ Why Do ZooKeeper Servers Fail to Start After a Large Number of Znodes Are Created?
Updated on 2026-06-27 GMT+08:00
Question
When an excessive number of znodes are created, the ZooKeeper cluster can enter an unrecoverable fault state. Subsequent restart attempts fail, and the following error pattern is captured in the ZooKeeper server logs:
Logs of followers:
2016-06-23 08:00:18,763 | WARN  | QuorumPeer[myid=26](plain=/10.16.9.138:2181)(secure=disabled) | Exception when following the leader | org.apache.zookeeper.server.quorum.Follower.followLeader(Follower.java:93)
java.net.SocketTimeoutException: Read timed out
    at java.net.SocketInputStream.socketRead0(Native Method)
    at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
    at java.net.SocketInputStream.read(SocketInputStream.java:170)
    at java.net.SocketInputStream.read(SocketInputStream.java:141)
    at java.io.BufferedInputStream.fill(BufferedInputStream.java:246)
    at java.io.BufferedInputStream.read(BufferedInputStream.java:265)
    at java.io.DataInputStream.readInt(DataInputStream.java:387)
    at org.apache.jute.BinaryInputArchive.readInt(BinaryInputArchive.java:63)
    at org.apache.zookeeper.server.quorum.QuorumPacket.deserialize(QuorumPacket.java:83)
    at org.apache.jute.BinaryInputArchive.readRecord(BinaryInputArchive.java:99)
    at org.apache.zookeeper.server.quorum.Learner.readPacket(Learner.java:156)
    at org.apache.zookeeper.server.quorum.Learner.registerWithLeader(Learner.java:276)
    at org.apache.zookeeper.server.quorum.Follower.followLeader(Follower.java:75)
    at org.apache.zookeeper.server.quorum.QuorumPeer.run(QuorumPeer.java:1094)
2016-06-23 08:00:18,764 | INFO  | QuorumPeer[myid=26](plain=/10.16.9.138:2181)(secure=disabled) | shutdown called | org.apache.zookeeper.server.quorum.Follower.shutdown(Follower.java:198)
java.lang.Exception: shutdown Follower
    at org.apache.zookeeper.server.quorum.Follower.shutdown(Follower.java:198)
    at org.apache.zookeeper.server.quorum.QuorumPeer.stopFollower(QuorumPeer.java:1141)
    at org.apache.zookeeper.server.quorum.QuorumPeer.run(QuorumPeer.java:1098)
Logs of the leader:
2016-06-23 07:30:57,481 | WARN  | QuorumPeer[myid=25](plain=/10.16.9.136:2181)(secure=disabled) | Unexpected exception | org.apache.zookeeper.server.quorum.QuorumPeer.run(QuorumPeer.java:1108)
java.lang.InterruptedException: Timeout while waiting for epoch to be acked by quorum
    at org.apache.zookeeper.server.quorum.Leader.waitForEpochAck(Leader.java:1221)
    at org.apache.zookeeper.server.quorum.Leader.lead(Leader.java:487)
    at org.apache.zookeeper.server.quorum.QuorumPeer.run(QuorumPeer.java:1105)
2016-06-23 07:30:57,482 | INFO  | QuorumPeer[myid=25](plain=/10.16.9.136:2181)(secure=disabled) | Shutdown called | org.apache.zookeeper.server.quorum.Leader.shutdown(Leader.java:623)
java.lang.Exception: shutdown Leader! reason: Forcing shutdown
    at org.apache.zookeeper.server.quorum.Leader.shutdown(Leader.java:623)
    at org.apache.zookeeper.server.quorum.QuorumPeer.stopLeader(QuorumPeer.java:1149)
    at org.apache.zookeeper.server.quorum.QuorumPeer.run(QuorumPeer.java:1110)
Answer
Creating an excessive number of znodes forces a massive volume of data to synchronize between the leader and follower nodes during cluster startup. If this synchronization phase does not complete within the configured timeout limit, a timeout error triggers, preventing the ZooKeeper servers from starting.
Go to the All Configurations page of the ZooKeeper service by referring to Modifying Cluster Service Configuration Parameters. To recover ZooKeeper servers, increase the values of syncLimit and initLimit in the ZooKeeper configuration file zoo.cfg until ZooKeeper servers are successfully started.
Table 1 Parameters
Default Value
syncLimit
Interval (unit: tick) at which data is synchronized between the follower and the leader. If the leader does not respond to the follower within the specified time, the connection between the leader and follower cannot be set up.
15
initLimit
Interval (unit: tick) within which the connection and synchronization between the follower and leader must be completed.
15
If ZooKeeper servers do not recover even after initLimit and syncLimit are set to 300 ticks, check that no other application is killing the ZooKeeper. For example, if the parameter value is 300 and the ticket duration is 2000 ms, the maximum synchronization duration is 600s (300 x 2000 ms).
There may exist the situation where an overwhelming amount of data is created in ZooKeeper and it takes long to synchronize data between the follower and the leader and to save data to the hard disk. This means that ZooKeeper needs to run for a long time. Ensure that no other monitoring application kills the ZooKeeper while ZooKeeper is running.
