On this page
Show all
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using ZooKeeper/ ZooKeeper Common Configuration Parameters
Updated on 2024-10-25 GMT+08:00
Navigation path for setting parameters:
Go to the All Configurations page of ZooKeeper by referring to Modifying Cluster Service Configuration Parameters. Enter a parameter name in the search box.
Table 1 Parameters
Default Value
skipACL
Specifies whether to skip the permission check of the ZooKeeper node.
no
maxClientCnxns
Specifies the maximum number of connections of ZooKeeper. It is recommended this parameter is set to a larger value in scenarios with a large number of connections.
2000
LOG_LEVEL
Specifies the log level. This parameter can be set to DEBUG during commissioning.
INFO
acl.compare.shortName
Specifies whether to perform ACL authentication only by principal username when the Znode ACL authentication type is SASL.
true
synclimit
Specifies the interval of synchronization between the follower and leader (unit: tick). If the leader does not respond within the specified time range, the connection cannot be established.
15
tickTime
Specifies the duration of a tick (in milliseconds). It is the basic time unit used by ZooKeeper, which defines heartbeat and timeout durations.
4000
The ZooKeeper internal time is determined by ticktime and synclimit. To increase the ZooKeeper internal timeout interval, increase the timeout interval for the client to connect to ZooKeeper.
