Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using YARN/ Common Issues About Yarn/ How Do I Limit the Size of Application Diagnostic Messages Stored in the ZKstore?
Updated on 2026-06-27 GMT+08:00
Question
How do I limit the size of application diagnostic messages stored in the ZKstore?
Answer
In some cases, it has been observed that diagnostic messages may grow infinitely. Because diagnostic messages are stored in the ZKstore, it is not recommended that you allow diagnostic messages to grow indefinitely. Therefore, a property parameter is needed to set the maximum size of the diagnostic message.
To set the yarn.app.attempt.diagnostics.limit.kc parameter, perform the following steps:
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Cluster > Services > Yarn > Configurations > All Configurations.
  3. Search for and modify the following parameter.
    Table 1 Parameter description
    Default Value
    Maximum size of the diagnostics message of an application attempt.
    It is measured in kilobytes (KB) (number of characters x 1024).
    When ZooKeeper is used to store application status data, the size of diagnostic messages must be limited to prevent YARN from overloading ZooKeeper. If yarn.resourcemanager.state-store.max-completed-applications is set to a large value, you need to decrease the value of this property to limit the total size of stored data.
    64
  4. Save the settings. Restart the expired service or instance for the configuration to take effect.
