Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Tez/ Typical Tez Configuration Parameters
Navigation path for setting parameters:
On Manager, choose Cluster > Service > Tez > Configuration > All Configurations.
Enter a parameter name in the search box.
Parameter description
| Parameter | Description | Default Value |
| property.tez.log.dir | TezUI log directory | /var/log/Bigdata/tez/tezui |
| property.tez.log.level | TezUI log level | INFO |
Parent topic: Using Tez
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
