On this page
Show all
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Spark/Spark2x/ Common Issues About Spark/ Spark SQL and DataFrame/ Why Is the "Code of method ... grows beyond 64 KB" Error Message Displayed When I Run Complex SQL Statements?
Updated on 2023-04-28 GMT+08:00
Question
When I run a complex SQL statement, for example, SQL statements with multiple layers of nesting statements and a single layer statement contains a large number of logic clauses such as case when, an error message indicating that the code of a certain method exceeds 64 KB is displayed. The log is as follows:
java.util.concurrent.ExecutionException: java.lang.Exception: failed to compile: org.codehaus.janino.JaninoRuntimeException: Code of method "(Lorg/apache/spark/sql/catalyst/expressions/GeneratedClass$SpecificUnsafeProjection;Lorg/apache/spark/sql/catalyst/InternalRow;)V" of class "org.apache.spark.sql.catalyst.expressions.GeneratedClass$SpecificUnsafeProjection" grows beyond 64 KB
Answer
If Project Tungsten is enabled, Spark will use codegen method to generate Java code for part of execution plan. However, each function in Java code to be compiled by JDK must be less than 64 KB. If complex SQL statements are run, the function in the Java code generated by codegen may exceed 64 KB, causing compilation failure.
To solve the problem, go to the spark-defaults.conf file on the client and set the spark.sql.codegen.wholeStage parameter to false to disable Project Tungsten.
