Why Does 16 Terabytes of Text Data Fails to Be Converted into 4 Terabytes of Parquet Data?
Question
When the default configuration is used, 16 terabytes of text data fails to be converted into 4 terabytes of parquet data, and the error information below is displayed. Why?
Job aborted due to stage failure: Task 2866 in stage 11.0 failed 4 times, most recent failure: Lost task 2866.6 in stage 11.0 (TID 54863, linux-161, 2): java.io.IOException: Failed to connect to /10.16.1.11:23124 at org.apache.spark.network.client.TransportClientFactory.createClient(TransportClientFactory.java:214) at org.apache.spark.network.client.TransportClientFactory.createClient(TransportClientFactory.java:167) at org.apache.spark.network.netty.NettyBlockTransferService$$anon$1.createAndStart(NettyBlockTransferService.scala:92)
Table 1 lists the default configuration.
        Parameter  |
        Description  |
        Example Value  |
        spark.sql.shuffle.partitions  |
        Number of shuffle data blocks during the shuffle operation.  |
        200  |
        spark.shuffle.sasl.timeout  |
        Timeout interval of SASL authentication for the shuffle operation. Unit: second  |
        120s  |
        spark.shuffle.io.connectionTimeout  |
        Timeout interval for connecting to a remote node during the shuffle operation. Unit: second  |
        120s  |
        spark.network.timeout  |
        Timeout interval for all network connection operations. Unit: second  |
        360s  |
Answer
The current data volume is 16 TB, but the number of partitions is only 200. As a result, each task is overloaded and the preceding problem occurs.
To solve the preceding problem, you need to adjust the parameters.
- Increase the number of partitions to divide the task into smaller ones.
 - Increase the timeout interval during task execution.
Set the following parameters in the {Client installation directory}/Spark/spark/conf/spark-defaults.conf file on the client.
       Parameter  |
       Description  |
       Default number of partitions to use during data shuffling. The recommended value is 4501.  |
       Timeout interval for SASL authentication during a shuffle operation. The recommended value is 2000s.  |
       Timeout interval for establishing connections between shuffle servers and clients during a shuffle operation. The recommended value is 3000s.  |
       Default timeout for all network interactions within a Spark application. The recommended value is 3600s.  |
