What Can I Do If "Connection to ip:port has been quiet for xxx ms while there are outstanding requests" Is Reported When Spark Executes an Application and the Application Ends?
Question
When Spark executes an application, an error similar to the following is reported and the application ends. What can I do?
2016-04-20 10:42:00,557 | ERROR | [shuffle-server-2] | Connection to 10-91-8-208/10.18.0.115:57959 has been quiet for 180000 ms while there are outstanding requests. Assuming connection is dead; please adju
st spark.network.timeout if this is wrong. | org.apache.spark.network.server.TransportChannelHandler.userEventTriggered(TransportChannelHandler.java:128)
2016-04-20 10:42:00,558 | ERROR | [shuffle-server-2] | Still have 1 requests outstanding when connection from 10-91-8-208/10.18.0.115:57959 is closed | org.apache.spark.network.client.TransportResponseHandl
er.channelUnregistered(TransportResponseHandler.java:102)
2016-04-20 10:42:00,562 | WARN | [yarn-scheduler-ask-am-thread-pool-160] | Error sending message [message = DoShuffleClean(application_1459995017785_0108,319)] in 1 attempts | org.apache.spark.Logging$clas
s.logWarning(Logging.scala:92)
java.io.IOException: Connection from 10-91-8-208/10.18.0.115:57959 closed
at org.apache.spark.network.client.TransportResponseHandler.channelUnregistered(TransportResponseHandler.java:104)
at org.apache.spark.network.server.TransportChannelHandler.channelUnregistered(TransportChannelHandler.java:94)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelUnregistered(AbstractChannelHandlerContext.java:158)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelUnregistered(AbstractChannelHandlerContext.java:144)
at io.netty.channel.ChannelInboundHandlerAdapter.channelUnregistered(ChannelInboundHandlerAdapter.java:53)
at io.netty.channel.DefaultChannelPipeline.fireChannelUnregistered(DefaultChannelPipeline.java:739)
at io.netty.channel.AbstractChannel$AbstractUnsafe$8.run(AbstractChannel.java:659)
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:357)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:357)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:111)
at java.lang.Thread.run(Thread.java:745)
2016-04-20 10:42:00,573 | INFO | [dispatcher-event-loop-14] | Starting task 177.0 in stage 1492.0 (TID 1996351, linux-254, PROCESS_LOCAL, 2106 bytes) | org.apache.spark.Logging$class.logInfo(Logging.scala:
59)
2016-04-20 10:42:00,574 | INFO | [task-result-getter-0] | Finished task 85.0 in stage 1492.0 (TID 1996259) in 191336 ms on linux-254 (106/3000) | org.apache.spark.Logging$class.logInfo(Logging.scala:59)
2016-04-20 10:42:00,811 | ERROR | [Yarn application state monitor] | Yarn application has already exited with state FINISHED! | org.apache.spark.Logging$class.logError(Logging.scala:75) Answer
Symptom: The value of spark.rpc.io.connectionTimeout is less than the value of spark.rpc.askTimeout. In full GC or network delay scenarios, when the channel reaches the expiration time and still receives no response, the channel is terminated. When detecting that the channel is terminated, the AM considers the driver as disconnected, and the entire application is stopped.
Solution:
Configure the following parameter in the {Client installation directory}/Spark/spark/conf/spark-defaults.conf file on the Spark client or by running the set command. During parameter configuration, ensure that the channel expiration time (spark.rpc.io.connectionTimeout) is greater than or equal to the RPC response timeout (spark.rpc.askTimeout).
| Parameter | Description | Example Value |
| spark.rpc.askTimeout | RPC response timeout. If this parameter is not set, the value of spark.network.timeout is used by default. | 120s |
