Configuring Multiple Concurrent Clients to Connect to JDBCServer
Multiple clients can be connected to JDBCServer at the same time. However, if the number of concurrent tasks is too large, the default configuration of JDBCServer must be optimized to adapt to the scenario.
- Set the fair scheduling policy of JDBCServer.
    The default scheduling policy of Spark is FIFO, which may cause a failure of short tasks in multi-task scenarios. Therefore, the fair scheduling policy must be used in multi-task scenarios to prevent task failure.
- For details about how to configure Fair Scheduler in Spark, visit http://archive.apache.org/dist/spark/docs/3.1.1/job-scheduling.html#scheduling-within-an-application.
 - Configure Fair Scheduler on the JDBC client.
- Run the following statement in either the Beeline CLI or custom JDBC code. The PoolName parameter indicates a scheduling pool for fair scheduling.
SET spark.sql.thriftserver.scheduler.pool=PoolName;
 - Run the SQL command. The Spark task will be executed in the preceding scheduling pool.
 - Set the BroadCastHashJoin timeout interval.
    There is a timeout parameter of BroadCastHashJoin. The task query fails if the query period exceeds the preset timeout interval. In multi-task scenarios, the Spark task of BroadCastHashJoin may fail due to resource preemption. Therefore, it is necessary to modify the timeout interval in the spark-defaults.conf file of JDBCServer.
Table 1 Parameter description Parameter
Example Value
spark.sql.broadcastTimeout
The timeout interval in the broadcast table of BroadcastHashJoin. If there are many concurrent tasks, set the parameter to a larger value or a negative number.
-1 (Numeral type. The actual value is 5 minutes.)
