Updated on 2026-06-27 GMT+08:00
Spark Log Overview
Log Description
Log paths:
  • Executor run log: ${BIGDATA_DATA_HOME}/hadoop/data${i}/nm/containerlogs/application_${appid}/container_{$contid}
    The logs of running tasks are stored in the preceding path. After the running is complete, the system determines whether to aggregate the logs to an HDFS directory based on the YARN configuration. For details, see Common YARN Parameters.
  • Other logs: /var/log/Bigdata/spark2x
Log archiving rule:
  • When tasks are submitted in yarn-client or yarn-cluster mode, executor log files are stored each time when the size of the log files reaches 50 MB. A maximum of 10 log files can be reserved without being compressed.
  • The JobHistory2x log file is backed up each time when the size of the log file reaches 100 MB. A maximum of 100 log files can be reserved without being compressed.
  • The JDBCServer2x log file is backed up each time when the size of the log file reaches 100 MB. A maximum of 100 log files can be reserved without being compressed.
  • The IndexServer2x log file is backed up each time when the size of the log file reaches 100 MB. A maximum of 100 log files can be reserved without being compressed.
  • The JDBCServer2x audit log file is backed up each time when the size of the log file reaches 20 MB by default. A maximum of 20 log files can be reserved without being compressed.
  • The log file size and the number of compressed files to be reserved can be configured on FusionInsight Manager.
Table 1 Spark2x log list
Log Type
Name
SparkResource2x logs
spark.log
Spark2x service initialization log
prestart.log
Prestart script log
cleanup.log
Cleanup log file for instance installation and uninstallation
spark-availability-check.log
Spark2x service health check log
spark-service-check.log
Spark2x service check log
JDBCServer2x logs
JDBCServer-start.log
JDBCServer2x startup log
JDBCServer-stop.log
JDBCServer2x stop log
JDBCServer.log
JDBCServer2x run log on the server
jdbc-state-check.log
JDBCServer2x health check log
jdbcserver-omm-pid***-gc.log.*.current
JDBCServer2x process GC log
spark-omm-org.apache.spark.sql.hive.thriftserver.HiveThriftProxyServer2-***.out*
JDBCServer2x process startup log. If the process stops, the jstack information is printed.
JobHistory2x logs
jobHistory-start.log
JobHistory2x startup log
jobHistory-stop.log
JobHistory2x stop log
JobHistory.log
JobHistory2x running process log If this file is unexpectedly deleted while JobHistory is running, the JobHistory service remains unaffected, but log data will be lost. The JobHistory.log file is regenerated, and logging resumes only after the JobHistory service is restarted.
jobhistory-omm-pid***-gc.log.*.current
JobHistory2x process GC log
spark-omm-org.apache.spark.deploy.history.HistoryServer-***.out*
JobHistory2x process startup log. If the process stops, the jstack information is printed.
IndexServer2x logs
IndexServer-start.log
IndexServer2x startup log
IndexServer-stop.log
IndexServer2x stop log
IndexServer.log
IndexServer2x run log on the server
indexserver-state-check.log
IndexServer2x health check log
indexserver-omm-pid***-gc.log.*.current
IndexServer2x process GC log
spark-omm-org.apache.spark.sql.hive.thriftserver.IndexServerProxy-***.out*
IndexServer2x process startup log. If the process stops, the jstack information is printed.
Audit Log
jdbcserver-audit.log
ranger-audit.log
Log levels
Table 2 describes the log levels supported by Spark2x. The priorities of log levels are ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log levels
Level
ERROR
Error information about the current event processing
WARN
Exception information about the current event processing
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
To modify log levels, perform the following operations:
By default, the service does not need to be restarted after the Spark2x log levels are configured.
  2. Choose Cluster > Services > Spark2x and click Configurations.
  3. Select All Configurations.
  4. On the menu bar on the left, select the log menu of the target role.
  5. Select a desired log level.
  6. Click Save. Then, click OK.
Log Format
Table 3 Log Format
Type
Format
Example
Run log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>
2014-09-22 11:16:23,980 INFO DAGScheduler: Final stage: Stage 0(reduce at SparkPi.scala:35)
