Changing Spark Log Levels
In some scenarios, to locate problems or check information by changing the log level,
you can add the -Dlog4j.configuration.watch=true parameter to the JVM parameter of a process before the process is started. After the process is started, you can modify the log4j configuration file corresponding to the process to change the log level.
The following processes support the dynamic setting of log levels: driver, executor, ApplicationMaster, JobHistory, and JDBCServer.
Allowed log levels are as follows: FATAL, ERROR, WARN, INFO, DEBUG, TRACE, and ALL.
Configuration Description
Add the following parameters to the JVM parameter corresponding to a process.
| Parameter | Description | Example Value |
| -Dlog4j.configuration.watch | Indicates a JVM parameter of a process. If this parameter is set to true, the dynamic configuration of log levels is enabled. | Left blank, indicating that the dynamic configuration of log levels is disabled |
Table 2 lists the JVM parameters of the driver, executor, and ApplicationMaster processes. Set the JVM parameters in the {Client installation directory}/Spark/spark/conf/spark-defaults.conf file on the Spark client. Set the log levels of the driver, executor, and ApplicationMaster processes in the log4j configuration file specified by the -Dlog4j.configuration parameter.
| spark.driver.extraJavaOptions | Indicates the JVM parameter of the driver process. | INFO |
| spark.executor.extraJavaOptions | Indicates the JVM parameter of the executor process. | INFO |
| spark.yarn.am.extraJavaOptions | Indicates the JVM parameter of the ApplicationMaster process. | INFO |
Table 3 describes the JVM parameters of JobHistory Server and JDBCServer. Set the parameters in the ENV_VARS configuration file. Set the log levels of JobHistory Server and JDBCServer in the log4j2.properties configuration file.
| GC_OPTS | Indicates the JVM parameter of the JobHistory Server process. | INFO |
| SPARK_SUBMIT_OPTS | Indicates the JVM parameter of the JDBCServer process. | INFO |
Example:
To change the log level of the executor process to DEBUG dynamically, modify the spark.executor.extraJavaOptions JVM parameter of the executor process in the spark-defaults.conf file and run the following command to add the following configuration before the process is started:
After the user application is submitted, change the log level in the Log4j configuration file (for example, Dlog4j.configuration=file:${BIGDATA_HOME}/FusionInsight_Spark2x_xxx/install/FusionInsight-Spark2x-*/spark/conf/log4j2-executor.properties) specified by the Dlog4j.configuration parameter in spark.executor.extraJavaOptions to DEBUG.
rootLogger.level = DEBUG
It takes several seconds for the DEBUG level to take effect.
