Updated on 2026-06-27 GMT+08:00
Configuring the Spark Multi-Tenant Mode
In multi-active instance mode, JDBCServer operates in YARN-client mode, but by default, only one YARN resource queue is available. This creates a resource bottleneck. To address this limitation, multi-tenant mode is introduced.
In multi-tenant mode, JDBCServers are bound with tenants. Each tenant corresponds to one or more JDBCServers, and a JDBCServer provides services for only one tenant. Different tenants can be configured with different YARN queues to implement resource isolation. In addition, JDBCServer can dynamically start as required to avoid resource waste.
Configuration Description
    For details, see Accessing FusionInsight Manager.
  1. Choose Cluster > Services > Spark2x or Spark, click Configurations and then All Configurations, search for the following parameters, and adjust their values.
    Table 1 Parameter description
    Example Value
    spark.proxyserver.hash.enabled
    Specifies whether to connect to ProxyServer using the Hash algorithm.
    • true: The Hash algorithm is used. In multi-tenant mode, this parameter must be set to true.
    • false: A random connection is used. In multi-active instance mode, this parameter must be set to false.
    After this parameter is modified, you need to download the client again.
    true
    spark.thriftserver.proxy.enabled
    Specifies whether to use the multi-tenant mode.
    • false: The multi-instance mode is used.
    • true: The multi-tenant mode is used.
    true
    spark.thriftserver.proxy.maxThriftServerPerTenancy
    Specifies the maximum number of JDBCServer instances that can be started by a tenant in multi-tenant mode.
    Value range: 1 to 2147483647
    2
    spark.thriftserver.proxy.maxSessionPerThriftServer
    Specifies the maximum number of sessions in a single JDBCServer instance in multi-tenant mode. If the number of sessions exceeds this value and the number of JDBCServer instances does not exceed the upper limit, a new JDBCServer instance is started. Otherwise, an alarm log is output.
    200
    spark.thriftserver.proxy.sessionWaitTime
    Specifies the wait time, in milliseconds, before a JDBCServer instance is stopped when it has no session connections in multi-tenant mode.
    180000
    spark.thriftserver.proxy.sessionThreshold
    In multi-tenant mode, when the session usage (formula: number of current sessions/spark.thriftserver.proxy.maxSessionPerThriftServer x number of current JDBCServer instances) of the JDBCServer instance reaches the threshold, a new JDBCServer instance is automatically added.
    100
    spark.thriftserver.proxy.healthcheck.period
    Specifies the interval, in milliseconds, at which the JDBCServer proxy checks the health status of the JDBCServer in multi-tenant mode.
    120000
    spark.thriftserver.proxy.healthcheck.recheckTimes
    Specifies the number of JDBCServer health check retries conducted by the JDBCServer proxy in multi-tenant mode.
    6
    spark.thriftserver.proxy.healthcheck.waitTime
    Specifies the wait time, in milliseconds, for JDBCServer to respond to a health check request sent by the JDBCServer proxy.
    10000
    spark.thriftserver.proxy.session.check.interval
    Specifies the period of JDBCServer proxy sessions in multi-tenant mode.
    6h
    spark.thriftserver.proxy.idle.session.timeout
    Specifies the idle time interval of a JDBCServer proxy session in multi-tenant mode. If no operation is performed within this period, the session is closed.
    7d
    spark.thriftserver.proxy.idle.session.check.operation
    Specifies whether to check that operations still exist on a JDBCServer proxy session when the session is checked for expiration in multi-tenant mode.
    • true: Check whether operations still exist on a JDBCServer proxy session when the session is checked for expiration.
    • false: Do not check whether operations still exist on a JDBCServer proxy session when the session is checked for expiration.
    true
    spark.thriftserver.proxy.idle.operation.timeout
    Specifies the timeout interval of an operation in multi-tenant mode. An operation that times out is closed.
    5d
    hive.spark.client.server.connect.timeout
    Specifies the timeout duration for client connections in multi-tenant mode.
    5min
  1. After the parameter settings are modified, click Save, perform operations as prompted, and wait until the settings are saved successfully.
  2. After the Spark server configurations are updated, if Configure Status is Expired, restart the component for the configurations to take effect.
    Figure 1 Modifying Spark configurations
    On the Spark dashboard page, choose More > Restart Service or Service Rolling Restart, enter the administrator password, and wait until the service restarts.
    Components are unavailable during the restart, affecting upper-layer services in the cluster. To minimize the impact, perform this operation during off-peak hours or after confirming that the operation does not have adverse impact.
Helpful Links
For more information about Spark multi-tenancy, see Spark2x Multi-tenant.
