On this page
Show all
Permission Parameters of the Spark Client and Server
This section describes how to configure SparkSQL permission management functions (client configuration is similar to server configuration). To enable table permission, add following configurations on the client and server:
  • spark-defaults.conf configuration file
    Table 1 Parameter description (1)
    Default Value
    spark.sql.authorization.enabled
    Specifies whether to enable permission authentication of the datasource statement. It is recommended that the parameter value be set to true to enable permission authentication.
    true
  • hive-site.xml configuration file
    Table 2 Parameter description (2)
    Default Value
    hive.metastore.uris
    Specifies the MetaStore service address of the Hive component, for example, thrift://10.10.169.84:21088,thrift://10.10.81.37:21088.
    hive.metastore.sasl.enabled
    Specifies whether the MetaStore service uses SASL to improve security. The table permission function must be enabled.
    true
    hive.metastore.kerberos.principal
    Specifies the principal of the MetaStore service in the Hive component, for example, hive/hadoop.<system domain name>@<system domain name>.
    hive-metastore/_HOST@EXAMPLE.COM
    hive.metastore.thrift.sasl.qop
    After the SparkSQL permission management function is enabled, set the parameter to auth-conf.
    auth-conf
    hive.metastore.token.signature
    Specifies the token identifier of the MetaStore service, which is set to HiveServer2ImpersonationToken.
    hive.security.authenticator.manager
    Specifies the manager authenticated by the Hive client, which is set to org.apache.hadoop.hive.ql.security.SessionStateUserGroupAuthenticator.
    org.apache.hadoop.hive.ql.security.SessionStateUserMSGroupAuthenticator
    hive.security.authorization.enabled
    Specifies whether to enable client authentication, which is set to true.
    true
    hive.security.authorization.createtable.owner.grants
    Specifies which permissions are granted to the owner who creates the table, which is set to ALL.
    ALL
  • core-site.xml configuration file of the MetaStore service
    Table 3 Parameter description (3)
    Default Value
    hadoop.proxyuser.spark.hosts
    Specifies the hosts from which Spark users can be masqueraded, which is set to *, indicating all hosts.
    hadoop.proxyuser.spark.groups
    Specifies the user groups from which Spark users can be masqueraded, which is set to *, indicating all user groups.
