On this page
Oozie Log Overview
Updated on 2023-04-28 GMT+08:00
Log Description
Log path: The default storage paths of Oozie log files are as follows:
  • Run log: /var/log/Bigdata/oozie
  • Audit log: /var/log/Bigdata/audit/oozie
Log archiving rule: Oozie logs are classified into run logs, script logs, and audit logs. The maximum size of a run log file is 20 MB, and a maximum of 20 run log files can be reserved. The maximum size of an audit log file is 20 MB, and a maximum of 20 audit log files can be reserved.
A compressed log file is generated for oozie.log every hour. 720 compressed files (log files of one month) are retained by default.
Table 1 Oozie log list
Log Type
Log File Name
Run log
jetty.log
Oozie built-in jetty server log file, which is used to process the request and response information of OozieServlet
jetty.out
Oozie process startup log file
oozie_db_temp.log
Oozie database connection log
oozie-instrumentation.log
Oozie dashboard log file, which records the Oozie running status and configuration information of each component
oozie-jpa.log
openJPa run log file
oozie.log
Oozie run log file
oozie-<SSH_USER>-<DATE>-<PID>-gc.log
Log file that records the garbage collection of the Oozie service
oozie-ops.log
Oozie operation log file
check-serviceDetail.log
Oozie health check logs
oozie-error.log
Oozie running error logs
threadDump-<DATE>.log
Log file that records stack information when the service process exits normally
Script logs
postinstallDetail.log
Work log file generated after the installation and before the startup
prestartDetail.log
Pre-startup log file
startDetail.log
Service startup log file
stopDetail.log
Service stop log file
upload-sharelib.log
Operation logs uploaded by sharelib
Audit log
oozie-audit.log
Audit log
Log Level
Table 2 describes the log levels provided by Oozie.
The priorities of log levels are ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the set level are printed. The number of printed logs decreases as the configured log level increases.
Table 2 Log levels
Level
ERROR
Logs of this level record abnormal information about events that cause process exceptions.
WARN
Logs of this level record exception information about the current event processing.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record system information and information about database underlying data transmission.
To modify log levels, perform the following operations:
  2. Choose Cluster > Name of the desired cluster > Services > Oozie > Configurations.
  3. Select All Configurations.
  4. On the menu bar on the left, select the log menu of the target role.
  5. Select a desired log level.
  6. Click Save, and then click OK. The settings take effect after the processing is complete.
Log Formats
The following table lists the Oozie log formats.
Table 3 Log formats
Log Type
Format
Example
Run log
<yyyy-MM-dd HH:mm:ss,SSS><Log level><Location where the log event occurs><Log level><Message in the log>
2015-05-29 21:01:45,268 INFO StatusTransitService$StatusTransitRunnable:539 - USER[-] GROUP[-] Released lock for [org.apache.oozie.service.StatusTransitService]
Script logs
<yyyy-MM-dd HH:mm:ss,SSS><Host name > <Log level > <Message in the log>
2015-06-01 17:18:03 001 suse11-192-168-0-111 oozie INFO Running oozie service check script
Audit log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log Level>|< Thread name | | Message in the log | Location where the log event occurs
2015-06-01 22:38:41,323 | INFO | http-bio-21003-exec-8 | IP [192.168.0.111] USER [null], GROUP [null], APP [null], JOBID [null], OPERATION [null], PARAMETER [null], RESULT [SUCCESS], HTTPCODE [200], ERRORCODE [null], ERRORMESSAGE [null] | org.apache.oozie.util.XLog.log(XLog.java:539)
