Submitting an Oozie MapReduce Job Using Hue
This section describes how to submit an Oozie job of the MapReduce type on the Hue web UI.
- Create a workflow. For details, see Creating a Workflow Using Hue.
- On the workflow editing page, select
next to MapReduce job and drag it to the operation area. - In the displayed MapReduce job dialog box, set Jar name, for example, to /user/admin/examples/apps/map-reduce/lib/oozie-examples-5.1.0.jar. Click Add.
- Click PROPERTIES+ to add input and output properties.
For example, set the value of mapred.input.dir to /user/admin/examples/input-data/text and set the value of mapred.output.dir to /user/admin/examples/output-data/map-reduce_workflow.
- Click the configuration button
in the upper right corner. On the configuration page that is displayed, click Delete + to delete a directory, for example, /user/admin/examples/output-data/map-reduce_workflow. - Click
in the upper right corner of the Oozie editor.
If you need to modify the job name before saving the job (default value: My Workflow), click the name directly for modification, for example, MapReduce-Workflow.
- After the configuration is saved, click
, and submit the job.
After the job is submitted, you can view the related contents of the job, such as the detailed information, logs, and processes, on Hue.
