Oozie Client Configurations
This section describes how to use the Oozie client in an O&M scenario or service scenario. Oozie can submit multiple types of tasks, such as Hive, Spark2x, Loader, MapReduce, Java, DistCp, Shell, HDFS, SSH, SubWorkflow, Streaming, and scheduled tasks.
- The client has been installed in a directory, for example, /opt/client. For details, see Installing a Client. The client directory in the following operations is only an example. Change it based on site requirements.
- Service component users have been created by the MRS cluster administrator. In security mode, machine-machine users need to download the keytab file. A human-machine user must change the password upon the first login.
Using the Oozie Client
- Log in to the node where the client is installed as the client installation user.
- Run the following command to switch to the client installation directory (change it to the actual installation directory):
cd /opt/client
- Run the following command to configure environment variables:
source bigdata_env
- Check the cluster authentication mode.
- If the cluster is in security mode, run the following command to authenticate the user: exampleUser indicates the name of the user who submits tasks.
kinit exampleUser
- If the cluster is in normal mode, go to 5.
- Perform the following operations to configure Hue:
- Configure the Spark2x environment (skip this step if the Spark2x task is not involved):
hdfs dfs -put /opt/client/Spark2x/spark/jars/*.jar /user/oozie/share/lib/spark2x/
When the JAR package in the HDFS directory /user/oozie/share changes, you need to restart the Oozie service.
- Upload the Oozie configuration file and JAR package to HDFS.
hdfs dfs -mkdir /user/exampleUser
hdfs dfs -put -f /opt/client/Oozie/oozie-client-*/examples /user/exampleUser/
- exampleUser indicates the name of the user who submits tasks.
- If the user who submits the task and other files except job.properties are not changed, client installation directory Oozie/oozie-client-*/examples can be repeatedly used after being uploaded to HDFS.
- Resolve the JAR file conflict between Spark and Yarn about Jetty.
hdfs dfs -rm -f /user/oozie/share/lib/spark/jetty-all-9.2.22.v20170606.jar
- In normal mode, if Permission denied is displayed during the upload, run the following commands:
su - omm
source /opt/client/bigdata_env
hdfs dfs -chmod -R 777 /user/oozie
exit
- The following describes how to submit a MapReduce job on the Oozie client.
- Run the following commands to modify the job execution configuration file:
cd /opt/client/Oozie/oozie-client-*/examples/apps/map-reduce/
vi job.properties
nameNode=hdfs://hacluster resourceManager=10.64.35.161:8032 (10.64.35.161 is the service plane IP address of the Yarn resourceManager (active) node, and 8032 is the port number of yarn.resourcemanager.port) queueName=default examplesRoot=examples user.name=admin oozie.wf.application.path=${nameNode}/user/${user.name}/${examplesRoot}/apps/map-reduce # HDFS upload path outputDir=map-reduce oozie.wf.rerun.failnodes=true - Run the following command to execute the Oozie job:
oozie job -oozie https://Host name of the Oozie role:21003/oozie/ -config job.properties -run
21003 indicates the running port of Oozie HTTPS requests. You can log in to FusionInsight Manager, choose Cluster > Services > Oozie > Configurations, and search for OOZIE_HTTPS_PORT in the search box.
[root@kwephispra44947 map-reduce]# oozie job -oozie https://kwephispra44948:21003/oozie/ -config job.properties -run ...... job: 0000000-200730163829770-oozie-omm-W
- Log in to FusionInsight Manager. For details, see Accessing FusionInsight Manager.
- Choose Cluster > Name of the desired cluster > Services > Oozie, click the hyperlink next to Oozie WebUI to go to the Oozie page, and view the task execution result on the Oozie web UI. Figure 1 Task execution result
