On this page
Show all
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Hive/ Common Issues About Hive/ How to Perform Operations on Local Files with Hive User-Defined Functions
Updated on 2024-10-25 GMT+08:00
Question
How to perform operations on local files (such as reading the content of a file) with Hive user-defined functions?
Answer
By default, you can perform operations on local files with their relative paths in UDF. The following are sample codes:
public String evaluate(String text) {
  // some logic
  File file = new File("foo.txt");
  // some logic
  // do return here
In Hive, upload the file foo.txt used in UDF to HDFS, such as hdfs://hacluster/tmp/foo.txt. You can perform operations on the foo.txt file by creating UDF with the following sentences:
create function testFunc as 'some.class' using jar 'hdfs://hacluster/somejar.jar', file 'hdfs://hacluster/tmp/foo.txt';
In abnormal cases, if the value of hive.fetch.task.conversion is more, you can perform operations on local files in UDF by using absolute path instead of relative path. In addition, you must ensure that the file exists on all HiveServer nodes and NodeManager nodes and omm user have corresponding operation rights.
