On this page
Show all
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HDFS/ Common Issues About HDFS/ When Does a Balance Process in HDFS, Shut Down and Fail to be Executed Again?
Updated on 2024-10-25 GMT+08:00
Question
After I start a Balance process in HDFS, the process is shut down abnormally. If I attempt to execute the Balance process again, it fails again.
Answer
After a Balance process is executed in HDFS, another Balance process can be executed only after the /system/balancer.id file is automatically released.
However, if a Balance process is shut down abnormally, the /system/balancer.id has not been released when the Balance is executed again, which triggers the append /system/balancer.id operation.
  • If the time spent on releasing the /system/balancer.id file exceeds the soft-limit lease period 60 seconds, executing the Balance process again triggers the append operation, which preempts the lease. The last block is in construction or under recovery status, which triggers the block recovery operation. The /system/balancer.id file cannot be closed until the block recovery completes. Therefore, the append operation fails.
    After the append /system/balancer.id operation fails, the exception message RecoveryInProgressException is displayed.
    org.apache.hadoop.ipc.RemoteException(org.apache.hadoop.protocol.RecoveryInProgressException): Failed to APPEND_FILE /system/balancer.id for DFSClient because lease recovery is in progress. Try again later.
  • If the time spent on releasing the /system/balancer.id file is within 60 seconds, the original client continues to own the lease and the exception AlreadyBeingCreatedException occurs and null is returned to the client. The following exception message is displayed on the client:
    java.io.IOException: Cannot create any NameNode Connectors.. Exiting...
Either of the following methods can be used to solve the problem:
  • Execute the Balance process again after the hard-limit lease period expires for 1 hour, when the original client has released the lease.
  • Delete the /system/balancer.id file before executing the Balance process again.
