Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HDFS/ HDFS FAQs/ What Can I Do If the DataNode Capacity Is Incorrectly Calculated?
Updated on 2025-11-13 GMT+08:00
Question
The capacity of a DataNode fails to calculate when multiple data.dir directories are configured in a disk partition.
Answer
Currently, the capacity is calculated based on disks, which is similar to the df command in Linux. Ideally, users do not configure multiple data.dir directories in a disk partition. Otherwise, all data will be written to the same disk, greatly deteriorating the performance.
Configure them as below.
For example, if a node contains the following disks:
host-4:~ # df -h
Filesystem      Size    Used    Avail    Use%   Mounted on
/dev/sda1       352G   11G      324G    4%      /
udev              190G    252K   190G    1%      /dev
tmpfs             190G   72K      190G    1%     /dev/shm
/dev/sdb1       2.7T    74G      2.5T      3%    /data1
/dev/sdc1       2.7T    75G      2.5T      3%    /data2
/dev/sdd1       2.7T    73G      2.5T      3%    /da
Recommended configuration:
<property>
<name>dfs.datanode.data.dir</name>
<value>/data1/datadir/,/data2/datadir,/data3/datadir</value>
</property>
Unrecommended configuration:
<property>
<value>/data1/datadir1/,/data2/datadir1,/data3/datadir1,/data1/datadir2,data1/datadir3,/data2/datadir2,/data2/datadir3,/data3/datadir2,/data3/datadir3</value>
</property>
