On this page
Show all
NameNode Startup Is Slow
Question
The NameNode startup is slow when it is restarted immediately after a large number of files (for example, 1 million files) are deleted.
Answer
It takes time for the DataNode to delete the corresponding blocks after files are deleted. When the NameNode is restarted immediately, it checks the block information reported by all DataNodes. If a deleted block is found, the NameNode generates the corresponding INFO log information, as shown below:
2015-06-10 19:25:50,215 | INFO  | IPC Server handler 36 on 25000 | BLOCK* processReport:
blk_1075861877_2121067 on node 10.91.8.218:9866 size 10249 does not belong to any file |
org.apache.hadoop.hdfs.server.blockmanagement.BlockManager.processReport(BlockManager.java:1854)
A log is generated for each deleted block. A file may contain one or more blocks. Therefore, after startup, the NameNode spends a large amount of time printing logs when a large number of files are deleted. As a result, the NameNode startup becomes slow.
To address this issue, the following operations can be performed to speed up the startup:
  1. After a large number of files are deleted, wait until the DataNode deletes the corresponding blocks and then restart the NameNode.
    You can run the hdfs dfsadmin -report command to check the disk space and check whether the files have been deleted.
  2. If a large number of the preceding logs are generated, you can change the NameNode log level to ERROR so that the NameNode stops printing such logs.
    After the NameNode is restarted, change the log level back to INFO. You do not need to restart the service after changing the log level.
