How Do I Fix Region Overlapping?
Question
When the hbck tool is used to check the region status, if the log contains ERROR: (regions region1 and region2) There is an overlap in the region chain or ERROR: (region region1) Multiple regions have the same startkey: xxx, overlapping exists in some regions. How do I solve this problem?
Answer
To rectify the fault, perform the following steps:
- Run the hbase hbck -j ${CLIENT_HOME}/HBase/hbase/tools/hbase-hbck2-1.1.0-h0.cbu.mrs.*.jar fixInconsistencies tableName command to restore the table that contains overlapping.
 - Run the hbase hbck -j ${CLIENT_HOME}/HBase/hbase/tools/hbase-hbck2-1.1.0-h0.cbu.mrs.*.jar listInconsistencies -run tableName command to check whether overlapping exists in the restored table.
 - Log in to FusionInsight Manager and choose Cluster > Name of the desired cluster > Services > HBase > More > Perform HMaster Switchover to complete the HMaster active/standby switchover.
- If overlapping does not exist, no further action is required.
 - If overlapping still exists, start from 1 to perform the recovery again.
