Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HBase/ HBase Troubleshooting/ How Do I Delete Residual Table Names in the table-lock Directory of ZooKeeper?
Updated on 2025-07-16 GMT+08:00
Question
In security mode, names of tables that failed to be created are unnecessarily retained in the table-lock node (default directory is /hbase/table-lock) of ZooKeeper. How do I delete these residual table names?
Answer
Perform the following steps:
  1. On the client, run the kinit command as the hbase user to obtain a security certificate.
  2. Run the hbase zkcli command to launch the ZooKeeper Command Line Interface (zkCLI).
  3. Run the ls /hbase/table command on the zkCLI to check whether the table name of the table that fails to be created exists.
    • If the table name exists, no further operation is required.
    • If the table name does not exist, run ls /hbase/table-lock to check whether the table name of the table fail to be created exist. If the table name exists, run the delete /hbase/table-lock/<table> command to delete the table name. In the delete /hbase/table-lock/<table> command. <table> indicates the residual table name.
